Canon Pixma MG7720 Control Panel Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
22
Past 30 Days:
64
All Time:
704
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If the control panel isn't working on your Canon Pixma MG7720 printer even after power cycling, or the control panel is damaged, use this guide to remove and replace the control panel. This component displays the settings and functions on your printer, made up of a variety of different buttons and controls.
Additional resources:
Electronics Donation and Recycling
Tools
    1. Canon Pixma MG7720 Control Panel Replacement, Control Panel: step 1, image 1 of 2 Canon Pixma MG7720 Control Panel Replacement, Control Panel: step 1, image 2 of 2
      • Open the front part of the printer and use your finger to depress the tab behind the front hinge in order to release it.
      • Repeat this with both the left and right front hinges.
      Ask FixBot
    2. Canon Pixma MG7720 Control Panel Replacement: step 2, image 1 of 3 Canon Pixma MG7720 Control Panel Replacement: step 2, image 2 of 3 Canon Pixma MG7720 Control Panel Replacement: step 2, image 3 of 3
      • Use the iFixit Opening Tool to pull the hinge away from the printer, then pull the hinge forward.
      • Repeat this with both of the rear hinges.
      Ask FixBot
    3. Canon Pixma MG7720 Control Panel Replacement: step 3, image 1 of 3 Canon Pixma MG7720 Control Panel Replacement: step 3, image 2 of 3 Canon Pixma MG7720 Control Panel Replacement: step 3, image 3 of 3
      • Use the iFixit Opening Tool to pull up on the back cover.
      • Use the tool lightly on both ends of the back cover to prevent bending.
      Ask FixBot
    4. Canon Pixma MG7720 Control Panel Replacement: step 4, image 1 of 2 Canon Pixma MG7720 Control Panel Replacement: step 4, image 2 of 2
      • Remove the tape on the connector.
      • Unplug it from both terminals by flipping up the tabs and pulling it out.
      Ask FixBot
Jaidan Perry
308 Reputation
2 Guides authored
Cuesta, Team 60-4, Krynen Fall 2024 Member of Cuesta, Team 60-4, Krynen Fall 2024
CUESTA-KRYNEN-F24S60G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 22
Past 30 Days: 64
All Time: 704
