Canon PIXMA iP3600 Printhead Replacement
    1. Canon PIXMA iP3600 Printhead Replacement, Ink Cartridges: step 1, image 1 of 1
      • Press the power button to turn on the printer.
      Ask FixBot
    2. Canon PIXMA iP3600 Printhead Replacement: step 2, image 1 of 1
      • Pull down the front output tray cover.
      Ask FixBot
    3. Canon PIXMA iP3600 Printhead Replacement: step 3, image 1 of 1
      • Lift the printer lid.
      Ask FixBot
    4. Canon PIXMA iP3600 Printhead Replacement: step 4, image 1 of 1
      • Allow the belt, containing ink cartridges, to adjust and center so that the ink cartridges are visible.
      Ask FixBot
    5. Canon PIXMA iP3600 Printhead Replacement: step 5, image 1 of 2 Canon PIXMA iP3600 Printhead Replacement: step 5, image 2 of 2
      • Push in the white clip to release the ink cartridge from the printhead.
      • Lift the ink cartridge from the printhead.
      • Repeat this process for the remaining ink cartridges.
      • You have successfully removed all ink cartridges.
      Ask FixBot
    1. Canon PIXMA iP3600 Printhead Replacement, Printhead: step 6, image 1 of 1
      • After removing all ink cartridges, lift the printhead lock lever.
      Ask FixBot
    2. Canon PIXMA iP3600 Printhead Replacement: step 7, image 1 of 1
      • Pull up and lift out the black piece that previously held the ink cartridges. This is the printhead.
      Ask FixBot
    3. Canon PIXMA iP3600 Printhead Replacement: step 8, image 1 of 1
      • You have successfully removed your printhead.
      Ask FixBot
6 other people completed this guide.
Caitlyn
1,223 Reputation
4 Guides authored
USF Tampa, Team 1-3, Leahy Fall 2014 Member of USF Tampa, Team 1-3, Leahy Fall 2014
USFT-LEAHY-F14S1G3
3 Members
48 Guides authored
1 Guide Comment
fairly helpful, especially the photo's. but I need advice on how to clean the printhead before trying to replace it,
a1halber - Reply Share
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 65
All Time: 9,579
