Up to 20% off select tools
Canon PIXMA MP620B Command Screen Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
112
All Time:
2,242
Comments: 2
2 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Easy
Tools
  • Phillips #0 Screwdriver
    5
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Replacing the command screen is relatively simple. You will have to pop off a few parts from the lid section of the printer in order to get at the back part of the command screen. Once you have access to the command screen and the attached chip, you can unplug a few wires and remove the screen with a philips-head screwdriver. After you have removed the screen, put in a replacement and close the printer back up. Good Luck!
    1. Canon PIXMA MP620B Command Screen Replacement, Open Printer Lid: step 1, image 1 of 1
      • Open top lid of the printer to reveal the scanner
      Ask FixBot
    2. Canon PIXMA MP620B Command Screen Replacement, Pull apart the two large lid plates: step 2, image 1 of 2 Canon PIXMA MP620B Command Screen Replacement, Pull apart the two large lid plates: step 2, image 2 of 2
      • Insert the spudger tool into the top lid in between the blue and the black panels.
      • Use this tool to pry the two panels apart
      Ask FixBot
    3. Canon PIXMA MP620B Command Screen Replacement, Take apart the two sections: step 3, image 1 of 1
      • After these two panels are separated, set the top panel to the side for now
      Ask FixBot
    4. Canon PIXMA MP620B Command Screen Replacement, Pull out wires leading to screen assembly: step 4, image 1 of 1
      • Unplug the two wires shown at the right of the command screen
      Ask FixBot
    5. Canon PIXMA MP620B Command Screen Replacement, Unscrew screen assembly: step 5, image 1 of 1
      • Unscrew the four screws shown to detach the command screen from the printer
      Ask FixBot
    6. Canon PIXMA MP620B Command Screen Replacement, Replace assembly: step 6, image 1 of 1
      • Take the detached command screen off of the printer and replace.
      Ask FixBot
4 other people completed this guide.
Author
with
Val Fedorikhin
860 Reputation
5 Guides authored
Cal Poly, Team 6-21, Maness Fall 2014 Member of Cal Poly, Team 6-21, Maness Fall 2014
CPSU-MANESS-F14S6G21
4 Members
60 Guides authored
2 Guide Comments
Ideas as to where to buy replacement screen assembly?
davepi49 - Reply Share
same question
Jan de Ruiter - Reply Share
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 112
All Time: 2,242
