Up to 20% off select tools
Canon PIXMA MP190 Ink Cartridge Replacement
Views: 11K
View statistics:
Past 24 Hours:
9
Past 7 Days:
35
Past 30 Days:
157
All Time:
10,900
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Over the life of the printer the ink cartridges will have to be replaced multiple times. Before attempting to replace the ink cartridges ensure that the printer is working properly which will facilitate in the cartridge exchange.
    1. Canon PIXMA MP190 Ink Cartridge  Replacement, Turn printer on.: step 1, image 1 of 1
      • The printer needs to be on in order to change the ink cartridges.
      Ask FixBot
    2. Canon PIXMA MP190 Ink Cartridge  Replacement, Locate Ink Cartridges: step 2, image 1 of 3 Canon PIXMA MP190 Ink Cartridge  Replacement, Locate Ink Cartridges: step 2, image 2 of 3 Canon PIXMA MP190 Ink Cartridge  Replacement, Locate Ink Cartridges: step 2, image 3 of 3
      • To locate the ink cartridges the paper output tray must be in the lowered position.
      • Next lift the scanning unit until the scanning support is vertical.
      • Lower the scanning unit until the scanning unit support seats in the scanning unit support slot.
      Ask FixBot
    3. Canon PIXMA MP190 Ink Cartridge  Replacement, Remove Ink Cartridge: step 3, image 1 of 3 Canon PIXMA MP190 Ink Cartridge  Replacement, Remove Ink Cartridge: step 3, image 2 of 3 Canon PIXMA MP190 Ink Cartridge  Replacement, Remove Ink Cartridge: step 3, image 3 of 3
      • Allow the printer to position the ink cartridge carrier into the ink cartridge removal location.
      • Before replacing the ink cartridge ensure the correct ink cartridge is installed.
      • Push down on the front edge of the ink cartridge.
      • Observe the angle at which the ink cartridge is removed.
      • Grasp ink cartridge and pull up and out to remove.
      Ask FixBot
4 other people completed this guide.
Author
with
Garret Wescott
597 Reputation
4 Guides authored
Michigan Tech, Team 1-5, Lauer Fall 2014 Member of Michigan Tech, Team 1-5, Lauer Fall 2014
MTU-LAUER-F14S1G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 35
Past 30 Days: 157
All Time: 10,900
