Canon EOS Rebel XTi Flash Module Replacement
Views: 3.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
105
All Time:
3,538
Comments: 9
5 comments on steps, 4 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 30 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
After long term use, it is possible that the flash module on your camera is stuck in position and can only be opened manually, or the light has burnt out. In either case it is safe to say that the module needs to be replaced. Use caution when removing the module because there are several wire harnesses connecting the module to the motherboard.
Tools
    1. Canon EOS Rebel XTi Flash Module Replacement, Battery: step 1, image 1 of 1
      • Place the camera upside down, and position it to where the back of the camera is visible.
      Ask FixBot
    2. Canon EOS Rebel XTi Flash Module Replacement: step 2, image 1 of 1
      • Pull the orange tab to the right to release the primary battery.
      Ask FixBot
    3. Canon EOS Rebel XTi Flash Module Replacement: step 3, image 1 of 1
      • To remove the secondary battery, reposition the camera to where the display screen is facing upwards.
      • Place your finger inside the empty battery compartment and pull away from the camera on the ridged battery tab.
      Ask FixBot
    1. Canon EOS Rebel XTi Flash Module Replacement, Memory Card: step 4, image 1 of 1
      • Place the camera on its side with the soft touch grip facing up and the top of the camera facing right.
      Ask FixBot
    2. Canon EOS Rebel XTi Flash Module Replacement: step 5, image 1 of 1
      • Slide the memory card door in the direction of the arrow engraved on the camera.
      • Once the door has slid open to its full position, lift up on the door.
      Ask FixBot
    3. Canon EOS Rebel XTi Flash Module Replacement: step 6, image 1 of 1
      • With the door open, push down the small black plunger next to the CF slot. The CF card will disengage from the slot and be ejected far enough that you can grasp it between thumb and forefinger and remove it from the slot.
      • The plunger will stay in its depressed position until a CF card is again inserted in the slot.
      Ask FixBot
    1. Canon EOS Rebel XTi Flash Module Replacement, Back Cover: step 7, image 1 of 1
      • Remove the three black M3x4mm JIS #000 screws on the bottom of the camera.
      Ask FixBot
    2. Canon EOS Rebel XTi Flash Module Replacement: step 8, image 1 of 2 Canon EOS Rebel XTi Flash Module Replacement: step 8, image 2 of 2
      • Remove the two black M3x6mm JIS #000 screws from the right side of the camera.
      Ask FixBot
    3. Canon EOS Rebel XTi Flash Module Replacement: step 9, image 1 of 1
      • Remove the two M3x5mm JIS #000 screws on the side of the camera opposite to the hand grip.
      Ask FixBot
    4. Canon EOS Rebel XTi Flash Module Replacement: step 10, image 1 of 1
      • Remove the following screws located in the memory card slot:
      • Two M3x2mm JIS #000 screws
      Ask FixBot
    5. Canon EOS Rebel XTi Flash Module Replacement: step 11, image 1 of 1
      • Gently pry off the back casing.
      • Before completely removing the back casing, be sure to disconnect the single ribbon cable running from the motherboard to the LCD display.
      • Use a spudger to lift the tab on the ribbon cable's ZIF connector.
      • Gently pull the ribbon cable out of the connector.
      Ask FixBot
    1. Canon EOS Rebel XTi Flash Module Replacement, Front Cover: step 12, image 1 of 1
      • Remove the following screws from the bottom of the camera:
      • Two M3x4.5mm JIS #000 screws
      • One M3x3mm JIS #000 screw
      Ask FixBot
    2. Canon EOS Rebel XTi Flash Module Replacement: step 13, image 1 of 1
      • Remove the following screws from the front of the camera:
      • Two M3x6mm JIS #000 screws
      Ask FixBot
    3. Canon EOS Rebel XTi Flash Module Replacement: step 14, image 1 of 1
      • Gently pry off the front casing.
      • There are no ribbon cables to remove for this portion of the disassembly.
      Ask FixBot
    1. Canon EOS Rebel XTi Flash Module Replacement, Top Cover: step 15, image 1 of 3 Canon EOS Rebel XTi Flash Module Replacement, Top Cover: step 15, image 2 of 3 Canon EOS Rebel XTi Flash Module Replacement, Top Cover: step 15, image 3 of 3
      • Remove the following screws from around the viewfinder:
      • One 10mm JIS #00 diopter screw
      • Two M3x6mm JIS #00 screws
      Ask FixBot
    2. Canon EOS Rebel XTi Flash Module Replacement: step 16, image 1 of 3 Canon EOS Rebel XTi Flash Module Replacement: step 16, image 2 of 3 Canon EOS Rebel XTi Flash Module Replacement: step 16, image 3 of 3
      • Remove the following screws on each side of the camera under the strap hooks:
      • One M3x5mm JIS #00 screw
      • One M3x4.5mm JIS #00 screw
      Ask FixBot
    3. Canon EOS Rebel XTi Flash Module Replacement: step 17, image 1 of 1
      • Separate the top casing from the electrical components enough to expose the wire harnesses that will need to be disconnected.
      • Ensure to remove the casing gently. There are several wire harnesses connecting the motherboard to components on the casing.
      Ask FixBot
    4. Canon EOS Rebel XTi Flash Module Replacement: step 18, image 1 of 1
      • Unplug the yellow connector located on the top of the camera.
      Ask FixBot
    5. Canon EOS Rebel XTi Flash Module Replacement: step 19, image 1 of 1
      • Disconnect the red connector located by the USB port.
      Ask FixBot
    1. Canon EOS Rebel XTi Flash Module Replacement, Flash Module: step 20, image 1 of 1
      • Use a JIS #000 screwdriver to remove the two 3 mm screws on the retention arms. There is one arm on each side of the module.
      • Do not lose the washers.
      • Remove the Retention Arms.
      Ask FixBot
    2. Canon EOS Rebel XTi Flash Module Replacement: step 21, image 1 of 2 Canon EOS Rebel XTi Flash Module Replacement: step 21, image 2 of 2
      • Use a JIS #000 screwdriver to remove the three 3 mm screws on the flash cap.
      • Remove the flash cap.
      Ask FixBot
    3. Canon EOS Rebel XTi Flash Module Replacement: step 22, image 1 of 2 Canon EOS Rebel XTi Flash Module Replacement: step 22, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the 7mm JIS #000 screw on the flash hinge.
      • Using the straight tweezers remove the spring from the hinge hole.
      Ask FixBot
    4. Canon EOS Rebel XTi Flash Module Replacement: step 23, image 1 of 1
      • Lift the side of the flash module closest to the on/off button towards the opposite side of the camera.
      • Pull the wires gently through the top of the camera to completely remove the flash module.
      • Be Gentle with the wires, even though they have already been disconnected when removing the top casing
      Ask FixBot
2 other people completed this guide.
Luis Calle
431 Reputation
3 Guides authored
USF Tampa, Team 8-6, Eyestone Fall 2015 Member of USF Tampa, Team 8-6, Eyestone Fall 2015
USFT-EYESTONE-F15S8G6
3 Members
108 Guides authored
4 Guide Comments
What is the part number for the Module, or where can it be readily found?
Scott - Reply Share
You have got to be kidding me.. my camera would never get to shoot another photo...
ssneed - Reply Share
Between steps 7 and 8, you left out removing the rest of the body covers. The top won't come off without removing the front, back, and sides.
Marvin Weaver - Reply Share
I fixed up the prereqs for this guide
Zephosk - Reply Share
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 105
All Time: 3,538
