Canon EOS Rebel XSi LCD Screen Replacement
  1. Canon EOS Rebel XSi LCD Screen Replacement, Back Panel: step 1, image 1 of 1
    • Squeeze the eyepiece between your index finger and thumb and lift up and off.
    Ask FixBot
  2. Canon EOS Rebel XSi LCD Screen Replacement: step 2, image 1 of 1
    • Using the PH000 screwdriver head, remove the four 4 mm screws on the bottom of the camera.
    Ask FixBot
  3. Canon EOS Rebel XSi LCD Screen Replacement: step 3, image 1 of 1
    • Using the PH000 screwdriver head, remove the two 3mm screws on the right side of the camera (from the LCD screen).
    Ask FixBot
  4. Canon EOS Rebel XSi LCD Screen Replacement: step 4, image 1 of 1
    • Remove grip by slowly peeling off.
    Ask FixBot
  5. Canon EOS Rebel XSi LCD Screen Replacement: step 5, image 1 of 1
    • Using the PH000 screwdriver, remove the four 4mm screws behind the eyepiece.
    Ask FixBot
  6. Canon EOS Rebel XSi LCD Screen Replacement: step 6, image 1 of 1
    • Using the PH000 screwdriver head, remove one 4 mm screw on the left side of the camera (from the LCD screen).
    Ask FixBot
  7. Canon EOS Rebel XSi LCD Screen Replacement: step 7, image 1 of 1
    • Remove the side panel by lifting off with fingers.
    Ask FixBot
  8. Canon EOS Rebel XSi LCD Screen Replacement: step 8, image 1 of 1
    • Use hands to pry off the back panel.
    Ask FixBot
  9. Canon EOS Rebel XSi LCD Screen Replacement, LCD Screen: step 9, image 1 of 1
    • Using the PH00 screwdriver head, unscrew four 4 mm screws and one 2 mm screw
    Ask FixBot
  10. Canon EOS Rebel XSi LCD Screen Replacement: step 10, image 1 of 2 Canon EOS Rebel XSi LCD Screen Replacement: step 10, image 2 of 2
    • Remove the metal plate covering inside of the LCD screen
    Ask FixBot
  11. Canon EOS Rebel XSi LCD Screen Replacement: step 11, image 1 of 1
    • Carefully disconnect the circuitry sheets from the white plastic bases
    Ask FixBot
  12. Canon EOS Rebel XSi LCD Screen Replacement: step 12, image 1 of 2 Canon EOS Rebel XSi LCD Screen Replacement: step 12, image 2 of 2
    • Using the plastic spudger, carefully pry out the LCD screen from the back panel
    Ask FixBot
Erik Mork
617 Reputation
5 Guides authored
Cal Poly, Team 22-10, Maness Winter 2017 Member of Cal Poly, Team 22-10, Maness Winter 2017
CPSU-MANESS-W17S22G10
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 38
All Time: 2,366
