Canon EOS Rebel XSi Front Panel Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
90
All Time:
1,949
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This replacement guide shows how to remove the device's front panel. This is necessary to access internal components that are located in the front.
Tools
    1. Canon EOS Rebel XSi Front Panel Replacement, Back Panel: step 1, image 1 of 1
      • Squeeze the eyepiece between your index finger and thumb and lift up and off.
      Ask FixBot
    2. Canon EOS Rebel XSi Front Panel Replacement: step 2, image 1 of 1
      • Using the PH000 screwdriver head, remove the four 4 mm screws on the bottom of the camera.
      Ask FixBot
    3. Canon EOS Rebel XSi Front Panel Replacement: step 3, image 1 of 1
      • Using the PH000 screwdriver head, remove the two 3mm screws on the right side of the camera (from the LCD screen).
      Ask FixBot
    4. Canon EOS Rebel XSi Front Panel Replacement: step 4, image 1 of 1
      • Remove grip by slowly peeling off.
      Ask FixBot
    5. Canon EOS Rebel XSi Front Panel Replacement: step 5, image 1 of 1
      • Using the PH000 screwdriver, remove the four 4mm screws behind the eyepiece.
      Ask FixBot
    6. Canon EOS Rebel XSi Front Panel Replacement: step 6, image 1 of 1
      • Using the PH000 screwdriver head, remove one 4 mm screw on the left side of the camera (from the LCD screen).
      Ask FixBot
    7. Canon EOS Rebel XSi Front Panel Replacement: step 7, image 1 of 1
      • Remove the side panel by lifting off with fingers.
      Ask FixBot
    8. Canon EOS Rebel XSi Front Panel Replacement: step 8, image 1 of 1
      • Use hands to pry off the back panel.
      Ask FixBot
    1. Canon EOS Rebel XSi Front Panel Replacement, Front Panel: step 9, image 1 of 1
      • Using the PH000 screwdriver head, remove the four 3mm screws on the front
      Ask FixBot
    2. Canon EOS Rebel XSi Front Panel Replacement: step 10, image 1 of 1
      • Remove front grip by gently peeling from the edge towards the center of the camera
      Ask FixBot
    3. Canon EOS Rebel XSi Front Panel Replacement: step 11, image 1 of 1
      • Using the PH000 screwdriver head, unscrew the 3 mm screw that was under the grip
      Ask FixBot
    4. Canon EOS Rebel XSi Front Panel Replacement: step 12, image 1 of 1
      • Using the PH000 screwdriver, remove the 4mm screw at the bottom of the camera
      Ask FixBot
    5. Canon EOS Rebel XSi Front Panel Replacement: step 13, image 1 of 3 Canon EOS Rebel XSi Front Panel Replacement: step 13, image 2 of 3 Canon EOS Rebel XSi Front Panel Replacement: step 13, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the front panel by using tweezers to pry the panel over the metal ring protrusion
      Ask FixBot
2 other people completed this guide.
Erik Mork
617 Reputation
5 Guides authored
Cal Poly, Team 22-10, Maness Winter 2017 Member of Cal Poly, Team 22-10, Maness Winter 2017
CPSU-MANESS-W17S22G10
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 90
All Time: 1,949
