Canon EOS Rebel XS Strap Loops Replacement
  1. Canon EOS Rebel XS Strap Loops Replacement, Eyepiece: step 1, image 1 of 2 Canon EOS Rebel XS Strap Loops Replacement, Eyepiece: step 1, image 2 of 2
    • Grasp the eyepiece with your fingers and slide upwards to remove it.
    Ask FixBot
  2. Canon EOS Rebel XS Strap Loops Replacement, Top Cover: step 2, image 1 of 2 Canon EOS Rebel XS Strap Loops Replacement, Top Cover: step 2, image 2 of 2
    • Using a PH000 screwdriver bit, remove the three black screws shown in the two pictures that are all 4 mm in length and 1 mm in diameter.
    Ask FixBot
  3. Canon EOS Rebel XS Strap Loops Replacement: step 3, image 1 of 1
    • Using a Phillips #000 screwdriver, remove the two black screws shown in the picture that are both 6 mm in length and 1.25 mm in diameter.
    Ask FixBot
  4. Canon EOS Rebel XS Strap Loops Replacement: step 4, image 1 of 1
    • Pull off the front cover.
    Ask FixBot
  5. Canon EOS Rebel XS Strap Loops Replacement: step 5, image 1 of 3 Canon EOS Rebel XS Strap Loops Replacement: step 5, image 2 of 3 Canon EOS Rebel XS Strap Loops Replacement: step 5, image 3 of 3
    • Using an opening tool (you can also use your nails, but try not to use something potentially damaging to the camera such as metal), separate the top cover from the rest of the camera!
    Ask FixBot
  6. Canon EOS Rebel XS Strap Loops Replacement, Strap Loops: step 6, image 1 of 3 Canon EOS Rebel XS Strap Loops Replacement, Strap Loops: step 6, image 2 of 3 Canon EOS Rebel XS Strap Loops Replacement, Strap Loops: step 6, image 3 of 3
    • Remove the two 5.0mm (.20in) silver screws from the first loop hole using a #00 Phillips screwdriver (Picture Two).
    • Remove the 6.8mm (.27in) wide head silver screw from the second loop hole using a #00 Phillips screwdriver (Picture Three).
    Ask FixBot
  7. Canon EOS Rebel XS Strap Loops Replacement: step 7, image 1 of 2 Canon EOS Rebel XS Strap Loops Replacement: step 7, image 2 of 2
    • Use your fingers to remove the loop holes.
    Ask FixBot
Daniel Bussone
1,289 Reputation
11 Guides authored
Cal Poly, Team 3-41, Regan Winter 2011 Member of Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 Members
21 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 28
All Time: 1,300
