Canon EOS Rebel XS LCD Replacement
  1. Canon EOS Rebel XS LCD Replacement, Latch Side Cover: step 1, image 1 of 1
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
    Ask FixBot
  2. Canon EOS Rebel XS LCD Replacement: step 2, image 1 of 1
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
    Ask FixBot
  3. Canon EOS Rebel XS LCD Replacement, Back Cover: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Remove the three long black screws from the bottom using a #00 Phillips screwdriver.
    • Use tweezers to lift the panel.
    Ask FixBot
  4. Canon EOS Rebel XS LCD Replacement: step 4, image 1 of 1
    • Once you have detached the back cover, use a pair of tweezers to lightly pull on strap found connecting the back cover to the camera.
    Ask FixBot
  5. Canon EOS Rebel XS LCD Replacement, LCD: step 5, image 1 of 1
    Buy
    • Use the tweezers to gently remove the straps (in the teal box).
    • Use the Phillips Screwdriver to remove the four screws (in the red dots).
    • Use your fingers to remove the silver plate.
    Ask FixBot
  6. Canon EOS Rebel XS LCD Replacement: step 6, image 1 of 1
    • Use the Spudger on the edges of the screen.
    • Once one end is lose, use the tweezers to lift the screen.
    Ask FixBot
4 other people completed this guide.
Daniel Bussone
1,289 Reputation
11 Guides authored
Cal Poly, Team 3-41, Regan Winter 2011 Member of Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 Members
21 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 33
All Time: 7,777
