Canon EOS Rebel XS 35mm Back Latch Replacement
  1. Canon EOS Rebel XS 35mm Back Latch Replacement, Bottom Cover: step 1, image 1 of 1
    • Use a Phillips #000 screwdriver to remove the 7 mm screw.
    • Use a Phillips #000 screwdriver to remove the five 4 mm screws.
    Ask FixBot
  2. Canon EOS Rebel XS 35mm Back Latch Replacement: step 2, image 1 of 1
    • With your fingers, push on the bottom cover towards the back of the camera until it clicks and separates.
    Ask FixBot
  3. Canon EOS Rebel XS 35mm Back Latch Replacement: step 3, image 1 of 1
    • Using tweezers or your fingers, carefully remove the five gears and set them aside temporarily.
    • These gears can fall out easily while you’re working, so keeping them organized will help prevent loss.
    Ask FixBot
  4. Canon EOS Rebel XS 35mm Back Latch Replacement, Top Cover: step 4, image 1 of 2 Canon EOS Rebel XS 35mm Back Latch Replacement, Top Cover: step 4, image 2 of 2
    • Using a PH000 screwdriver bit, remove the three black screws shown in the two pictures that are all 4 mm in length and 1 mm in diameter.
    Ask FixBot
  5. Canon EOS Rebel XS 35mm Back Latch Replacement: step 5, image 1 of 1
    • Using a Phillips #000 screwdriver, remove the two black screws shown in the picture that are both 6 mm in length and 1.25 mm in diameter.
    Ask FixBot
  6. Canon EOS Rebel XS 35mm Back Latch Replacement: step 6, image 1 of 1
    • Pull off the front cover.
    Ask FixBot
  7. Canon EOS Rebel XS 35mm Back Latch Replacement: step 7, image 1 of 3 Canon EOS Rebel XS 35mm Back Latch Replacement: step 7, image 2 of 3 Canon EOS Rebel XS 35mm Back Latch Replacement: step 7, image 3 of 3
    • Using an opening tool (you can also use your nails, but try not to use something potentially damaging to the camera such as metal), separate the top cover from the rest of the camera!
    Ask FixBot
  8. Canon EOS Rebel XS 35mm Back Latch Replacement, Back Latch: step 8, image 1 of 1
    • Once the front, top, and bottom covers have all been removed, it's time to remove the back latch! Using a paperclip or something similar (anything that's very skinny), push on the end of the skinny, silver, metal rod that vertically travels through the camera. Do this until enough of the rod pops out on the other side for the next step.
    Ask FixBot
  9. Canon EOS Rebel XS 35mm Back Latch Replacement: step 9, image 1 of 1
    • Remove the screw with a Phillips #00 screwdriver.
    • Remove the screw with a Phillips #000 screwdriver.
    Ask FixBot
  10. Canon EOS Rebel XS 35mm Back Latch Replacement: step 10, image 1 of 2 Canon EOS Rebel XS 35mm Back Latch Replacement: step 10, image 2 of 2
    • Remove the side piece to open the latch.
    • Carefully hold the camera around and not on the camera sensor.
    Ask FixBot
  11. Canon EOS Rebel XS 35mm Back Latch Replacement: step 11, image 1 of 2 Canon EOS Rebel XS 35mm Back Latch Replacement: step 11, image 2 of 2
    Tool used on this step:
    Buy
    • With a pair of tweezers or just your fingers, pull the rod completely out of the camera. The back latch should then completely detach from the camera.
    Ask FixBot
christiansvezia
1,136 Reputation
10 Guides authored
1 Guide Comment
This would be fantastic if only you'd noted a place to obtain a replacement latch from.
David Sanborn - Reply Share
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 60
All Time: 1,460
