Canon EOS Rebel T7i Front Cover Replacement
  1. Canon EOS Rebel T7i Front Cover Replacement, Back Cover: step 1, image 1 of 2 Canon EOS Rebel T7i Front Cover Replacement, Back Cover: step 1, image 2 of 2
    • Before beginning, remove the battery and SD card from the camera.
    • Using your thumbs, push up on the eyepiece to remove it.
    • Remove the battery door.
    • Open the battery door to about a 35° angle.
    • Pull the battery door straight outwards.
    Ask FixBot
  2. Canon EOS Rebel T7i Front Cover Replacement: step 2, image 1 of 3 Canon EOS Rebel T7i Front Cover Replacement: step 2, image 2 of 3 Canon EOS Rebel T7i Front Cover Replacement: step 2, image 3 of 3
    • Underneath the right I/F terminal cap, remove the following screws:
    • Two M1.7x5.5mm JIS #000 screws
    • On the right side of the camera, remove the following screws:
    • Two M1.7x4.5mm JIS #000 screws
    • On the back of the camera, remove the following screws next to the viewfinder:
    • Two M1.7x5.0mm Phillips #000 screws
    Ask FixBot
  3. Canon EOS Rebel T7i Front Cover Replacement: step 3, image 1 of 3 Canon EOS Rebel T7i Front Cover Replacement: step 3, image 2 of 3 Canon EOS Rebel T7i Front Cover Replacement: step 3, image 3 of 3
    • On the bottom of the camera, remove the following screws:
    • Four M1.7x5.0mm Phillips #000 screws
    • Using a plastic opening pick, partially peel up the top of the back rubber grip.
    • Carefully begin lifting the back cover up away from the camera body.
    • Do not lift it all the way off. There is still a ribbon cable attaching the back cover to the main PCB board.
    • Using a plastic spudger tool, gently pry off the back cover ribbon cable from the main PCB board.
    Ask FixBot
  4. Canon EOS Rebel T7i Front Cover Replacement, Front Cover: step 4, image 1 of 3 Canon EOS Rebel T7i Front Cover Replacement, Front Cover: step 4, image 2 of 3 Canon EOS Rebel T7i Front Cover Replacement, Front Cover: step 4, image 3 of 3
    • Underneath the left I/F terminal cap, remove the following screw:
    • M1.7x5.5mm JIS #000 screw
    • Using a plastic opening pick, peel off the front name plate.
    • Underneath where the name plate was, remove the following screw:
    • One M1.7x5.5mm Phillips #000 screw
    • Pull off the I/F terminal cover.
    Ask FixBot
  5. Canon EOS Rebel T7i Front Cover Replacement: step 5, image 1 of 3 Canon EOS Rebel T7i Front Cover Replacement: step 5, image 2 of 3 Canon EOS Rebel T7i Front Cover Replacement: step 5, image 3 of 3
    • On the front of the camera, remove the following screws:
    • Two M1.7x6.0mm JIS #000 screws
    Ask FixBot
  6. Canon EOS Rebel T7i Front Cover Replacement: step 6, image 1 of 1
    • Use a plastic spudger to pry up on the bottom of the front cover and lift it over the tripod socket.
    • Pull the front cover off the camera body.
    • Electric Shock Warning: With the front cover off, the high voltage capacitor on the DC PCB board is now exposed. It is recommended that you use a capacitor discharge tool to ensure the capacitor is fully discharged before proceeding further.
    Ask FixBot
Attached Documents
Zephosk
6,036 Reputation
39 Guides authored
LGBTQ Technicians Member of LGBTQ Technicians
Community
62 Members
109 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 20
All Time: 320
