Canon EOS Rebel T7i Back Cover Replacement
  1. Canon EOS Rebel T7i Back Cover Replacement, Back Cover: step 1, image 1 of 2 Canon EOS Rebel T7i Back Cover Replacement, Back Cover: step 1, image 2 of 2
    • Before beginning, remove the battery and SD card from the camera.
    • Using your thumbs, push up on the eyepiece to remove it.
    • Remove the battery door.
    • Open the battery door to about a 35° angle.
    • Pull the battery door straight outwards.
    Ask FixBot
  2. Canon EOS Rebel T7i Back Cover Replacement: step 2, image 1 of 3 Canon EOS Rebel T7i Back Cover Replacement: step 2, image 2 of 3 Canon EOS Rebel T7i Back Cover Replacement: step 2, image 3 of 3
    • Underneath the right I/F terminal cap, remove the following screws:
    • Two M1.7x5.5mm JIS #000 screws
    • On the right side of the camera, remove the following screws:
    • Two M1.7x4.5mm JIS #000 screws
    • On the back of the camera, remove the following screws next to the viewfinder:
    • Two M1.7x5.0mm Phillips #000 screws
    Ask FixBot
  3. Canon EOS Rebel T7i Back Cover Replacement: step 3, image 1 of 3 Canon EOS Rebel T7i Back Cover Replacement: step 3, image 2 of 3 Canon EOS Rebel T7i Back Cover Replacement: step 3, image 3 of 3
    • On the bottom of the camera, remove the following screws:
    • Four M1.7x5.0mm Phillips #000 screws
    • Using a plastic opening pick, partially peel up the top of the back rubber grip.
    • Carefully begin lifting the back cover up away from the camera body.
    • Do not lift it all the way off. There is still a ribbon cable attaching the back cover to the main PCB board.
    • Using a plastic spudger tool, gently pry off the back cover ribbon cable from the main PCB board.
    Ask FixBot
Attached Documents
Zephosk
6,036 Reputation
39 Guides authored
LGBTQ Technicians Member of LGBTQ Technicians
Community
62 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 38
All Time: 684
