Canon EOS Rebel T6i LCD Display Replacement
  1. Canon EOS Rebel T6i LCD Display Replacement, LCD Display: step 1, image 1 of 1
    • Remove the battery and use an anti-static wrist strap to ground yourself to prevent damage to device.
    • 2 screws on the side -1.3 mm
    Ask FixBot
  2. Canon EOS Rebel T6i LCD Display Replacement: step 2, image 1 of 2 Canon EOS Rebel T6i LCD Display Replacement: step 2, image 2 of 2
    • 4 screws are located on the opposite/interior side of screen case. Use the J000 gauge screw driver head to remove these 4 screws. Furthermore, these screws are a larger gauge then the other 2. Please sort these accordingly.
    • 4 small screws on back 1.58 mm
    Ask FixBot
  3. Canon EOS Rebel T6i LCD Display Replacement: step 3, image 1 of 2 Canon EOS Rebel T6i LCD Display Replacement: step 3, image 2 of 2
    • Following the removal of the 6 screws, Locate the joint of the casing. Place a flat lever inside this crevice and apply pressure. The case should simply pop open into the 2 casing pieces and the screen mechanism. Warning. No Dot try to remove bottom casing until next step.
    Ask FixBot
  4. Canon EOS Rebel T6i LCD Display Replacement: step 4, image 1 of 3 Canon EOS Rebel T6i LCD Display Replacement: step 4, image 2 of 3 Canon EOS Rebel T6i LCD Display Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • There are several components inside the casing. A board, a power cable, the screen and a ribbon cable. First, using tweezers lift the metallic clamp connecting the ribbon to the board.
    • WARNING. If the lever doesn't lift immediately, do not forcefully lift it. This could damage the ribbon and board. When reapplying the ribbon, secure connection.
    Ask FixBot
  5. Canon EOS Rebel T6i LCD Display Replacement: step 5, image 1 of 1
    • Now that the ribbon is disconnected, remove the board carefully and place it aside. This piece still works so leave it attached to camera.
    Ask FixBot
  6. Canon EOS Rebel T6i LCD Display Replacement: step 6, image 1 of 2 Canon EOS Rebel T6i LCD Display Replacement: step 6, image 2 of 2
    • The screen is glued into the casing. Remove the screen by carefulyl lifting along the edges of the case until the screen pops out. Place new screen into the existing casing. A small about of glue or adhesive may be necessary if their isn't sufficient adhesive remaining in the case. Repeat steps in reverse to reapply screen.
    Ask FixBot
  7. Canon EOS Rebel T6i LCD Display Replacement: step 7, image 1 of 1
    • If screen doesn't power on after replacing the battery, Go back and check connections of the ribbon.
    Ask FixBot
3 other people completed this guide.
4 Guide Comments
Very simple and great guide for. See the Canon T6i Bundle
Deve Lee - Reply Share
Thanks for this awesome guide its really useful for me. see the Canon 80D Bundle
9 Product Reviews - Reply Share
y las refacciones donde?
cafeplazay - Reply Share
Very useful website for DIY purposes, thanks
Biaka ralte - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 77
All Time: 5,326
