Canon EOS Rebel T5 SD Card Replacement
  1. Canon EOS Rebel T5 SD Card Replacement, Battery: step 1, image 1 of 1
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
    Ask FixBot
  2. Canon EOS Rebel T5 SD Card Replacement: step 2, image 1 of 1
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
    Ask FixBot
  3. Canon EOS Rebel T5 SD Card Replacement, SD Card: step 3, image 1 of 1
    Ask FixBot
  4. Canon EOS Rebel T5 SD Card Replacement: step 4, image 1 of 1
    • Open the battery compartment by lifting the card/battery door. You will see a thin SD Card slot below the battery.
    • Push in the old SD card until it clicks to remove it and then push in the new card until it clicks into place.
    Ask FixBot
3 other people completed this guide.
Austin Tucker
1,087 Reputation
4 Guides authored
USF Tampa, Team 16-4, Wollert Fall 2015 Member of USF Tampa, Team 16-4, Wollert Fall 2015
USFT-WOLLERT-F15S16G4
4 Members
18 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 65
All Time: 4,210
