Canon EOS Rebel T5 Back Cover Removal
  1. Canon EOS Rebel T5 Back Cover Removal, Battery: step 1, image 1 of 1
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
    Ask FixBot
  2. Canon EOS Rebel T5 Back Cover Removal: step 2, image 1 of 1
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
    Ask FixBot
  3. Canon EOS Rebel T5 Back Cover Removal, Back Cover: step 3, image 1 of 1
    • Turn the camera so that the back is facing to your right.
    • Remove the 5mm JIS #000 screw above the rubber USB port cover.
    Ask FixBot
  4. Canon EOS Rebel T5 Back Cover Removal: step 4, image 1 of 1
    • Remove the rubber piece.
    • Unscrew the two screws under the rubber cover to completely remove the rubber cover piece.
    • It is held in place by a notched tether, but can be easily manipulated to slide out.
    Ask FixBot
  5. Canon EOS Rebel T5 Back Cover Removal: step 5, image 1 of 1
    • Turn your camera so that the bottom is facing you.
    • Remove the four 5mm JIS #000 screws.
    Ask FixBot
  6. Canon EOS Rebel T5 Back Cover Removal: step 6, image 1 of 1
    • Now turn the camera so that the front is facing towards your right.
    • Remove the two remaining 5mm JIS #000 screws.
    Ask FixBot
  7. Canon EOS Rebel T5 Back Cover Removal: step 7, image 1 of 3 Canon EOS Rebel T5 Back Cover Removal: step 7, image 2 of 3 Canon EOS Rebel T5 Back Cover Removal: step 7, image 3 of 3
    • Now that all of the exterior screws have been removed, grip the camera firmly on both sides.
    • Gently pry the back panel from the main body of the camera.
    • There are two ribbon cables that need to be removed in order for the back panel to come free from the camera body, as indicated.
    • This back panel contains various control components of the camera as well as the LCD screen.
    Ask FixBot
6 other people completed this guide.
Johnyp
278 Reputation
1 Guide authored
USF Tampa, Team 16-4, Wollert Fall 2015 Member of USF Tampa, Team 16-4, Wollert Fall 2015
USFT-WOLLERT-F15S16G4
4 Members
18 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 70
All Time: 4,464
