Canon EOS Rebel T4i Battery Replacement
Views: 4.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
86
All Time:
4,213
Comments: 1
1 guide comment.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide will inform the user what to do if the battery needs to be replaced.
    1. Canon EOS Rebel T4i Battery Replacement, Battery: step 1, image 1 of 1
      • Locate the battery cover at the bottom of the camera.
      • Pull down on the black tab to open the cover.
      Ask FixBot
    2. Canon EOS Rebel T4i Battery Replacement: step 2, image 1 of 1
      • Push the grey tab on the right side of the battery.
      • Remove the battery from the slot.
      Ask FixBot
4 other people completed this guide.
Nimisha Patel
185 Reputation
1 Guide authored
Cal Poly, Team 12-33, Maness Spring 2014 Member of Cal Poly, Team 12-33, Maness Spring 2014
CPSU-MANESS-S14S12G33
4 Members
60 Guides authored
1 Guide Comment
Black tab on cover of the battery is constantly disengaging either when I am using or in my camera bag therefore battery runs down. Seems like a design fault to me. Anyone else having this problem ? Have been using sticky tape to keep it in place but still have a problem with the cover moving around and disengaging battery. Replacing with a new flimsy one from Canon at minimum cost of £40 is not on - knowing it will only happen again. I have given author 30 points for covering the topic but sadly have no idea how to solve this problem
esther allwood - Reply Share
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 86
All Time: 4,213
