Canon EOS Rebel G Viewfinder Replacement
  1. Canon EOS Rebel G Viewfinder Replacement, Front Panel: step 1, image 1 of 1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
    Ask FixBot
  2. Canon EOS Rebel G Viewfinder Replacement: step 2, image 1 of 2 Canon EOS Rebel G Viewfinder Replacement: step 2, image 2 of 2
    • Using your finger, peel back the textured grip so the components are separated.
    Ask FixBot
  3. Canon EOS Rebel G Viewfinder Replacement: step 3, image 1 of 3 Canon EOS Rebel G Viewfinder Replacement: step 3, image 2 of 3 Canon EOS Rebel G Viewfinder Replacement: step 3, image 3 of 3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
    Ask FixBot
  4. Canon EOS Rebel G Viewfinder Replacement, Top Panel: step 4, image 1 of 1
    • Turn Camera over.
    • Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
    Ask FixBot
  5. Canon EOS Rebel G Viewfinder Replacement: step 5, image 1 of 1
    • Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
    Ask FixBot
  6. Canon EOS Rebel G Viewfinder Replacement: step 6, image 1 of 1
    • Lay the camera on its back.
    • Unsolder the flash connection from the motherboard as noted by the blue circle.
    Ask FixBot
  7. Canon EOS Rebel G Viewfinder Replacement: step 7, image 1 of 3 Canon EOS Rebel G Viewfinder Replacement: step 7, image 2 of 3 Canon EOS Rebel G Viewfinder Replacement: step 7, image 3 of 3
    • Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
    Ask FixBot
  8. Canon EOS Rebel G Viewfinder Replacement, Viewfinder: step 8, image 1 of 1
    • Unscrew the screws on either side of the viewfinder until the viewfinder can be lifted off
    • Two 8.5 mm Phillips screws
    Ask FixBot
Kyle Reis
52 Reputation
4 Guides authored
Cal Poly, Team 14-9, Forte Spring 2012 Member of Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 26
All Time: 3,582
