Canon EOS Rebel G Front Panel Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
87
All Time:
1,423
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide shows you how to install the front panel of your camera.
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. Canon EOS Rebel G Front Panel Replacement, Front Panel: step 1, image 1 of 1
      • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
      Ask FixBot
    2. Canon EOS Rebel G Front Panel Replacement: step 2, image 1 of 2 Canon EOS Rebel G Front Panel Replacement: step 2, image 2 of 2
      • Using your finger, peel back the textured grip so the components are separated.
      Ask FixBot
    3. Canon EOS Rebel G Front Panel Replacement: step 3, image 1 of 3 Canon EOS Rebel G Front Panel Replacement: step 3, image 2 of 3 Canon EOS Rebel G Front Panel Replacement: step 3, image 3 of 3
      • Using the flat end of a spudger, loosen the connection between the front panel and the device.
      • Remove the front panel using your hands.
      Ask FixBot
Kyle Reis
52 Reputation
4 Guides authored
Cal Poly, Team 14-9, Forte Spring 2012 Member of Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 87
All Time: 1,423
