Canon EOS Rebel G Flash Replacement
    1. Canon EOS Rebel G Flash Replacement, Front Panel: step 1, image 1 of 1
      • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
      Ask FixBot
    2. Canon EOS Rebel G Flash Replacement: step 2, image 1 of 2 Canon EOS Rebel G Flash Replacement: step 2, image 2 of 2
      • Using your finger, peel back the textured grip so the components are separated.
      Ask FixBot
    3. Canon EOS Rebel G Flash Replacement: step 3, image 1 of 3 Canon EOS Rebel G Flash Replacement: step 3, image 2 of 3 Canon EOS Rebel G Flash Replacement: step 3, image 3 of 3
      • Using the flat end of a spudger, loosen the connection between the front panel and the device.
      • Remove the front panel using your hands.
      Ask FixBot
    1. Canon EOS Rebel G Flash Replacement, Flash: step 4, image 1 of 2 Canon EOS Rebel G Flash Replacement, Flash: step 4, image 2 of 2
      • Pop the flash up with your thumb
      Ask FixBot
    2. Canon EOS Rebel G Flash Replacement: step 5, image 1 of 1
      • Unscrew the two screws on the front of the flash near the bulb cover.
      Ask FixBot
    3. Canon EOS Rebel G Flash Replacement: step 6, image 1 of 3 Canon EOS Rebel G Flash Replacement: step 6, image 2 of 3 Canon EOS Rebel G Flash Replacement: step 6, image 3 of 3
      • Close the flash.
      • Lift the flash cover off.
      Ask FixBot
    4. Canon EOS Rebel G Flash Replacement: step 7, image 1 of 2 Canon EOS Rebel G Flash Replacement: step 7, image 2 of 2
      • Pull off yellow capacitor from flash wiring.
      Ask FixBot
    5. Canon EOS Rebel G Flash Replacement: step 8, image 1 of 1
      • Remove white cocking with a razor blade, and then unsolder connection.
      Ask FixBot
    6. Canon EOS Rebel G Flash Replacement: step 9, image 1 of 2 Canon EOS Rebel G Flash Replacement: step 9, image 2 of 2
      • Remove the flash cover to access the flash bulb.
      • After wires are unsoldered, slide flash bulb out from housing.
      Ask FixBot
Zach
46 Reputation
8 Guides authored
Cal Poly, Team 14-9, Forte Spring 2012 Member of Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 33
All Time: 3,162
