Canon EOS Rebel G Back Panel Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
86
All Time:
2,628
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Difficult
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
This guide will instruct you how to remove the back panel of your camera.
Tools
    1. Canon EOS Rebel G Back Panel Replacement, Front Panel: step 1, image 1 of 1
      • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
      Ask FixBot
    2. Canon EOS Rebel G Back Panel Replacement: step 2, image 1 of 2 Canon EOS Rebel G Back Panel Replacement: step 2, image 2 of 2
      • Using your finger, peel back the textured grip so the components are separated.
      Ask FixBot
    3. Canon EOS Rebel G Back Panel Replacement: step 3, image 1 of 3 Canon EOS Rebel G Back Panel Replacement: step 3, image 2 of 3 Canon EOS Rebel G Back Panel Replacement: step 3, image 3 of 3
      • Using the flat end of a spudger, loosen the connection between the front panel and the device.
      • Remove the front panel using your hands.
      Ask FixBot
    1. Canon EOS Rebel G Back Panel Replacement, Top Panel: step 4, image 1 of 1
      • Turn Camera over.
      • Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
      Ask FixBot
    2. Canon EOS Rebel G Back Panel Replacement: step 5, image 1 of 1
      • Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
      Ask FixBot
    3. Canon EOS Rebel G Back Panel Replacement: step 6, image 1 of 1
      • Lay the camera on its back.
      • Unsolder the flash connection from the motherboard as noted by the blue circle.
      Ask FixBot
    4. Canon EOS Rebel G Back Panel Replacement: step 7, image 1 of 3 Canon EOS Rebel G Back Panel Replacement: step 7, image 2 of 3 Canon EOS Rebel G Back Panel Replacement: step 7, image 3 of 3
      • Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
      Ask FixBot
    1. Canon EOS Rebel G Back Panel Replacement, Back Panel: step 8, image 1 of 1
      • Using a #00 Philllips screw driver, unscrew the 6.8 mm Phillips screw that holds the strap anchor noted by the red circle.
      • Remove the strap anchor.
      Ask FixBot
    2. Canon EOS Rebel G Back Panel Replacement: step 9, image 1 of 1
      • Unlatch the back panel.
      • Using a #00 Phillips screw driver, unscrew the six screws on the bottom of the camera.
      • One 7.4 mm Phillips screw
      • Two 6.0 mm Phillips screws
      • Two 4.4 mm Phillips screws
      • One 3.9 mm Phillips screw
      Ask FixBot
    3. Canon EOS Rebel G Back Panel Replacement: step 10, image 1 of 3 Canon EOS Rebel G Back Panel Replacement: step 10, image 2 of 3 Canon EOS Rebel G Back Panel Replacement: step 10, image 3 of 3
      Tool used on this step:
      Buy
      • From the bottom of the camera push the hinge rod in with your finger.
      • Return the camera to its upright position.
      • Use pliers (or tweezers) to pull the rod out from the top.
      Ask FixBot
Zach
46 Reputation
8 Guides authored
Cal Poly, Team 14-9, Forte Spring 2012 Member of Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 86
All Time: 2,628
