Canon EOS Digital Rebel (300D) Front Casing Replacement
    1. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove the front screws: step 1, image 1 of 1
      • Remove the two 7mm philips screws from the front casing.
      Ask FixBot
    2. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove bottom screws: step 2, image 1 of 1
      • Remove the three 1/8" philips screws from the bottom.
      • Remove the single 3/16" philips screw from the bottom.
      Ask FixBot
    3. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove the right side screws: step 3, image 1 of 1
      • Remove the two 1/8" philip screws from the right side of the front casing.
      Ask FixBot
    4. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove battery door: step 4, image 1 of 2 Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove battery door: step 4, image 2 of 2
      • Locate the lock of the battery door and pull it for allowing the door to be removed.
      • Remove the battery door.
      Ask FixBot
    5. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove the battery door hinge mount: step 5, image 1 of 1
      • Remove the two 1/8" philips screws from the hinge mount.
      • Take out the door hinge mount.
      Ask FixBot
    6. Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove internal screws: step 6, image 1 of 2 Canon EOS Digital Rebel (300D) Front Casing Replacement, Remove internal screws: step 6, image 2 of 2
      • Remove the screw holding the black cap which covers access holes to the screws holding the front casing to the battery compartment.
      • Remove the black cap pulling it to the right.
      • Remove the two 3/16" philips screws.
      Ask FixBot
Claudio Felix
893 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 46
All Time: 1,540
