Up to 20% off select tools
Canon EOS A2 Front Cover Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
101
All Time:
3,571
Comments: 5
5 comments on steps.
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Removing the front cover gives access to lens housing, and allows removal of the top cover.
    1. Canon EOS A2 Front Cover Replacement, Battery: step 1, image 1 of 1
      • Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
      Ask FixBot
    2. Canon EOS A2 Front Cover Replacement: step 2, image 1 of 1
      • Twist the tab clockwise to unlock the door, then pull outward from the camera to remove it.
      Ask FixBot
    3. Canon EOS A2 Front Cover Replacement: step 3, image 1 of 1
      • Remove the battery from inside the battery housing and set the cover aside.
      Ask FixBot
    1. Canon EOS A2 Front Cover Replacement, Front Cover: step 4, image 1 of 1
      • Remove the two 6.4mm screws above the lens aperture using a phillips #00 screw driver.
      Ask FixBot
    2. Canon EOS A2 Front Cover Replacement: step 5, image 1 of 1
      • Remove the 6.4mm screw from the inside of the flash bezel.
      • If the flash is locked down, insert the battery, then with the help of a pencil turn the rotary (CW or CCW) switch until the "125" is displayed in the LCD. Press the Flash symbol button. You should hear the latch from the flash, then you can manually lift the flash. If OK, then remove the battery from the camera
      Ask FixBot
    3. Canon EOS A2 Front Cover Replacement: step 6, image 1 of 1
      • Flip the camera upside down and remove the 5.4mm screw below the lens bezel on the front of the camera.
      Ask FixBot
    4. Canon EOS A2 Front Cover Replacement: step 7, image 1 of 1
      • Remove the 5.6mm screws behind the battery cover.
      Ask FixBot
    5. Canon EOS A2 Front Cover Replacement: step 8, image 1 of 1
      • Remove two 6.4mm screws on the latch mechanism on the right side of the camera.
      Ask FixBot
    6. Canon EOS A2 Front Cover Replacement: step 9, image 1 of 1
      • Remove the 6.4mm screw on the top of the inside edge of the battery hole.
      Ask FixBot
    7. Canon EOS A2 Front Cover Replacement: step 10, image 1 of 2 Canon EOS A2 Front Cover Replacement: step 10, image 2 of 2
      • Starting at the flash, carefully pull the front cover away from the camera.
      Ask FixBot
Author
with
Mark
197 Reputation
5 Guides authored
Cal Poly, Team 8-9, Regan Spring 2011 Member of Cal Poly, Team 8-9, Regan Spring 2011
CPSU-REGAN-S11S8G9
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 101
All Time: 3,571
