Up to 20% off select tools
Canon EOS A2 Control Dial Replacement
Views: 12K
View statistics:
Past 24 Hours:
5
Past 7 Days:
35
Past 30 Days:
209
All Time:
11,560
Comments: 15
6 comments on steps, 9 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 1 hour
Difficulty: Very difficult
Tools
Introduction
Go to step 1 ↓
The control dial on the canon EOS A2 lies underneath the top cover of the device. The front cover must also be removed in order to access this.
    1. Canon EOS A2 Control Dial Replacement, Battery: step 1, image 1 of 1
      • Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
      Ask FixBot
    2. Canon EOS A2 Control Dial Replacement: step 2, image 1 of 1
      • Twist the tab clockwise to unlock the door, then pull outward from the camera to remove it.
      Ask FixBot
    3. Canon EOS A2 Control Dial Replacement: step 3, image 1 of 1
      • Remove the battery from inside the battery housing and set the cover aside.
      Ask FixBot
    1. Canon EOS A2 Control Dial Replacement, Front Cover: step 4, image 1 of 1
      • Remove the two 6.4mm screws above the lens aperture using a phillips #00 screw driver.
      Ask FixBot
    2. Canon EOS A2 Control Dial Replacement: step 5, image 1 of 1
      • Remove the 6.4mm screw from the inside of the flash bezel.
      • If the flash is locked down, insert the battery, then with the help of a pencil turn the rotary (CW or CCW) switch until the "125" is displayed in the LCD. Press the Flash symbol button. You should hear the latch from the flash, then you can manually lift the flash. If OK, then remove the battery from the camera
      Ask FixBot
    3. Canon EOS A2 Control Dial Replacement: step 6, image 1 of 1
      • Flip the camera upside down and remove the 5.4mm screw below the lens bezel on the front of the camera.
      Ask FixBot
    4. Canon EOS A2 Control Dial Replacement: step 7, image 1 of 1
      • Remove the 5.6mm screws behind the battery cover.
      Ask FixBot
    5. Canon EOS A2 Control Dial Replacement: step 8, image 1 of 1
      • Remove two 6.4mm screws on the latch mechanism on the right side of the camera.
      Ask FixBot
    6. Canon EOS A2 Control Dial Replacement: step 9, image 1 of 1
      • Remove the 6.4mm screw on the top of the inside edge of the battery hole.
      Ask FixBot
    7. Canon EOS A2 Control Dial Replacement: step 10, image 1 of 2 Canon EOS A2 Control Dial Replacement: step 10, image 2 of 2
      • Starting at the flash, carefully pull the front cover away from the camera.
      Ask FixBot
    1. Canon EOS A2 Control Dial Replacement, Top Cover: step 11, image 1 of 1
      • Remove the 4.3mm screw below the camera strap ring.
      Ask FixBot
    2. Canon EOS A2 Control Dial Replacement: step 12, image 1 of 1
      • Remove two 4.8mm screws located on both sides of the eyepiece.
      Ask FixBot
    3. Canon EOS A2 Control Dial Replacement: step 13, image 1 of 1
      • Pull the top cover up slowly.
      • A ribbon cable is attached to the bottom of the top cover and the camera. Pull up very carefully to avoid damaging this.
      Ask FixBot
    4. Canon EOS A2 Control Dial Replacement: step 14, image 1 of 1
      • Once you have revealed the ribbon cable, gently let the top cover hang off the front of the camera. Use the plastic opening tool to gently pull the white tabs on the ribbon cable, releasing the ribbon cable.
      • If you pull the white tabs all the way out, just insert them back in to avoid losing them.
      Ask FixBot
    1. Canon EOS A2 Control Dial Replacement, Control Dial: step 15, image 1 of 3 Canon EOS A2 Control Dial Replacement, Control Dial: step 15, image 2 of 3 Canon EOS A2 Control Dial Replacement, Control Dial: step 15, image 3 of 3
      • Remove the 3mm screw from the back of the control dial while holding the front of the control dial.
      • Be ready to catch the control dial, button, and spring that will fall out with your hand.
      Ask FixBot
    2. Canon EOS A2 Control Dial Replacement: step 16, image 1 of 1
      • On the bottom side of the top bezel, remove the ring, detent ball and spring. Your control dial is now ready to be replaced with a working unit.
      Ask FixBot
7 other people completed this guide.
Author
with
Jessica
52 Reputation
1 Guide authored
Cal Poly, Team 8-9, Regan Spring 2011 Member of Cal Poly, Team 8-9, Regan Spring 2011
CPSU-REGAN-S11S8G9
4 Members
72 Guides authored
9 Guide Comments
Is it safe to do this procedure while a film is inside the camera?
Giovanni Murru - Reply Share
I was wondering if anyone could help me were I could possibly get the new parts?
I've looked around but found nothing relevant so far.
Thanks in advance,
Agoston Horanyi
horanyiagoston - Reply Share
Did you find the parts ? If no go to eBay.
as exemple : https://www.ebay.com/itm/Canon-EOS-A2E-R...
gilberto - Reply Share
I'm wondering if there is someone who can fix the mode selector for a reasonable price
zekesrule - Reply Share
How can I open the flash to get to the screw that needs to be removed in order to fix the rotary dial when the rotary dial is moving freely and the camera does not turn on?
Lucas - Reply Share
Past 24 Hours: 5
Past 7 Days: 35
Past 30 Days: 209
All Time: 11,560
