Up to 20% off select tools
Canon EOS A2 Battery Replacement
Views: 5.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
108
All Time:
5,938
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
Your battery may be the cause of many problems. Knowing how to access it is very important.
    1. Canon EOS A2 Battery Replacement, Battery: step 1, image 1 of 1
      • Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
      Ask FixBot
    2. Canon EOS A2 Battery Replacement: step 2, image 1 of 1
      • Twist the tab clockwise to unlock the door, then pull outward from the camera to remove it.
      Ask FixBot
    3. Canon EOS A2 Battery Replacement: step 3, image 1 of 1
      • Remove the battery from inside the battery housing and set the cover aside.
      Ask FixBot
2 other people completed this guide.
Author
with
Mark
197 Reputation
5 Guides authored
Cal Poly, Team 8-9, Regan Spring 2011 Member of Cal Poly, Team 8-9, Regan Spring 2011
CPSU-REGAN-S11S8G9
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 108
All Time: 5,938
