Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓This guide will show you how to replace the interface cover, which includes both the plastic cover and the rubber caps over the interface itself.
Note that the Phillips #000 screwdriver is marked as an optional tool as you can always use the JIS #000 screwdriver in its place (JIS screwdrivers won't damage Phillips head screws).
Before beginning, remove the battery and SD card from the camera.
Using your thumbs, push up on the eyepiece to remove it.
Remove the battery door.
Open the battery door to about a 35° angle.
Pull the battery door straight outwards.
