Canon EOS 60D USB Replacement connector
  1. Canon EOS 60D USB Replacement connector, Exchange of the connecter card: step 1, image 1 of 1
    • Also look at the pdf file or I have some photos that could not be deposited in this tutorial
    • Photograph of the broken plug, the central part is no longer centred and moves, hence the loss of USB connection with the computer
    Ask FixBot
  2. Canon EOS 60D USB Replacement connector, View of the defect: step 2, image 1 of 3 Canon EOS 60D USB Replacement connector, View of the defect: step 2, image 2 of 3 Canon EOS 60D USB Replacement connector, View of the defect: step 2, image 3 of 3
    • Seen from the broken socket, the central part almost no longer holds and goes wrong
    • Photo of the item to be replaced (new card)
    Ask FixBot
  3. Canon EOS 60D USB Replacement connector, Or buy the replacement card: step 3, image 1 of 1
    • After a long search, I was able to find the famous map on the Aliexpress website
    Ask FixBot
  4. Canon EOS 60D USB Replacement connector, tools required: step 4, image 1 of 1
    • Screwdrivers #00
    • Phone disassembly kit
    Ask FixBot
  5. Canon EOS 60D USB Replacement connector: step 5, image 1 of 1
    Ask FixBot
  6. Ask FixBot
  7. Canon EOS 60D USB Replacement connector, Location of the screws to be removed: step 7, image 1 of 2 Canon EOS 60D USB Replacement connector, Location of the screws to be removed: step 7, image 2 of 2
    Ask FixBot
  8. Canon EOS 60D USB Replacement connector, Trick: step 8, image 1 of 1
    • Small tip, to avoid losing the screws I put a magnet so that the screws are "glued" to the screwdriver
    Ask FixBot
  9. Canon EOS 60D USB Replacement connector, After the operations described in the video: step 9, image 1 of 3 Canon EOS 60D USB Replacement connector, After the operations described in the video: step 9, image 2 of 3 Canon EOS 60D USB Replacement connector, After the operations described in the video: step 9, image 3 of 3
    • Once this video has been dismantled, you must see this
    • We can move on to disassembly the card
    Ask FixBot
  10. Canon EOS 60D USB Replacement connector, Unbuttoning connecters and removal of screws: step 10, image 1 of 1
    • There are 5 screws left to loosen and 6 connecters to unbutton
    • Start removing the 2 connecters in photo 1 with a tweezer, take on the side of the plug without pulling the wires
    Ask FixBot
  11. Canon EOS 60D USB Replacement connector, Removal of connectors: step 11, image 1 of 1
    • Remove the two cables from these two connecters, as well as the screw on the right
    Ask FixBot
  12. Canon EOS 60D USB Replacement connector, Removal of the screws: step 12, image 1 of 1
    • 3 screws to remove, one of which is hidden under the yellow tape
    • Remove the plastic cable holder
    Ask FixBot
  13. Canon EOS 60D USB Replacement connector, Screw removal: step 13, image 1 of 1
    • Remove the last screw
    Ask FixBot
  14. Canon EOS 60D USB Replacement connector, Ribbon connecter: step 14, image 1 of 1
    • Detach the tablecloth by pulling underneath with a flat screwdriver or with an unfolded paper clip in the hole provided for this purpose
    Ask FixBot
  15. Canon EOS 60D USB Replacement connector, Clear the card: step 15, image 1 of 1
    • This is the most delicate part to gently clear the card by moving it without forcing it, until it finds its pivot point
    • Be careful, because at the moment there is still a connecter connected under the card. However, the cable is long enough to take it out without worry
    • At the curvature of the red thread, a small bent visible next to the screw hole is observed. It is probably he who makes it so difficult to remove the card.
    • There is a second one on the upper part of the card next to the screw that was under the yellow tape.
    Ask FixBot
  16. Canon EOS 60D USB Replacement connector, Video connecter removal: step 16, image 1 of 1
    • The connecter undoes very easily by levering on each side of the golden connecter
    • The wide arrow indicates where to pin the soft tablecloth
    Ask FixBot
  17. Canon EOS 60D USB Replacement connector, Card withdrawn: step 17, image 1 of 1
    • Exchange the deposited card
    Ask FixBot
  18. Canon EOS 60D USB Replacement connector, Reassembly of the card: step 18, image 1 of 1
    • Put the golden connecter back on, a slight pressure is enough
    Ask FixBot
  19. Canon EOS 60D USB Replacement connector, Identification of the card centring picot: step 19, image 1 of 1
    • We see where the plastic pin is located that holds the printed circuit board, next to the screw hole
    • Locate the same principle on the top of the map
    Ask FixBot
  20. Canon EOS 60D USB Replacement connector, Rest from the map: step 20, image 1 of 1
    • Reinsert the tablecloth into its connecter, without forcing, the hole of the tablecloth must be in the plastic pin to be in place
    Ask FixBot
  21. Canon EOS 60D USB Replacement connector, Installation of the cables: step 21, image 1 of 1
    • Be careful, the screw on the side comes to the arrowhead, the other hole must remain free for the screw of the plastic case (I was wrong)
    Ask FixBot
    • Proceeding with the opposite of the video, everything went well.
    • Just when you put the rear facade back, the screen no longer folded down completely, don't panic, just unlock the three side screws of the card you just changed. The different plastic parts must join without leaving an apparent day.
    • Review the end of the video or this problem is well explained, it is thanks to it that I solved this little problem
    Ask FixBot
  22. Canon EOS 60D USB Replacement connector: step 23, image 1 of 1
    • Use 3M spray mount glue to glue the rubber sheath on the case
    • Good luck and good photos
    Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
vallet
337 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 55
All Time: 1,407
