Canon EOS 60D Rear LCD Screen Replacement
  1. Canon EOS 60D Rear LCD Screen Replacement, Rear LCD Screen Dissasembly: step 1, image 1 of 1
    • Take the LCD out of its place to expose the Phillips #PH00 screws.
    • Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
    • Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
    Ask FixBot
  2. Canon EOS 60D Rear LCD Screen Replacement: step 2, image 1 of 1
    • Using a plastic opening tool, carefully pry off the back cover of the LCD.
    Ask FixBot
  3. Canon EOS 60D Rear LCD Screen Replacement: step 3, image 1 of 2 Canon EOS 60D Rear LCD Screen Replacement: step 3, image 2 of 2
    • Remove the 3 mm Phillips #PH00 silver screw on the side of the screen.
    • Turn the screen to remove the second 3 mm Phillips #PH00 silver screw.
    Ask FixBot
  4. Canon EOS 60D Rear LCD Screen Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Using the tweezers, carefully disconnect the rear connector by pulling it away from the screen.
    Ask FixBot
  5. Canon EOS 60D Rear LCD Screen Replacement, Rear LCD Screen: step 5, image 1 of 2 Canon EOS 60D Rear LCD Screen Replacement, Rear LCD Screen: step 5, image 2 of 2
    • Remove the two 2.5 mm Phillips #PH00 silver screws using the PH00 screwdriver.
    • Using the plastic Spudger opening tool, carefully lift up on the medal tabs next to where the screws were located.
    Ask FixBot
  6. Canon EOS 60D Rear LCD Screen Replacement: step 6, image 1 of 1
    • Finally, remove the LCD screen by grabbing the clear plastic tab and lifting it carefully.
    Ask FixBot
4 other people completed this guide.
Alejandro Cabrera
470 Reputation
2 Guides authored
USF Tampa, Team 16-6, Wollert Fall 2015 Member of USF Tampa, Team 16-6, Wollert Fall 2015
USFT-WOLLERT-F15S16G6
3 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 85
All Time: 9,238
