Canon EOS 60D Rear Cover Removal
  1. Canon EOS 60D Rear Cover Removal, Rear LCD Screen Dissasembly: step 1, image 1 of 1
    • Take the LCD out of its place to expose the Phillips #PH00 screws.
    • Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
    • Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
    Ask FixBot
  2. Canon EOS 60D Rear Cover Removal: step 2, image 1 of 1
    • Using a plastic opening tool, carefully pry off the back cover of the LCD.
    Ask FixBot
  3. Canon EOS 60D Rear Cover Removal: step 3, image 1 of 2 Canon EOS 60D Rear Cover Removal: step 3, image 2 of 2
    • Remove the 3 mm Phillips #PH00 silver screw on the side of the screen.
    • Turn the screen to remove the second 3 mm Phillips #PH00 silver screw.
    Ask FixBot
  4. Canon EOS 60D Rear Cover Removal: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Using the tweezers, carefully disconnect the rear connector by pulling it away from the screen.
    Ask FixBot
  5. Canon EOS 60D Rear Cover Removal, Removing Rear Cover: step 5, image 1 of 2 Canon EOS 60D Rear Cover Removal, Removing Rear Cover: step 5, image 2 of 2
    • Now, four 2.2 mm Phillips #PH00 screws holding a cover around the hinge should be visible.
    • Turn the swivel around to expose the remaining of the aforementioned screws.
    • Then use the PH00 screw driver to remove them.
    Ask FixBot
  6. Canon EOS 60D Rear Cover Removal: step 6, image 1 of 2 Canon EOS 60D Rear Cover Removal: step 6, image 2 of 2
    • The eye piece will slide right off with a firm push upwards.
    • Remove the 3.4 mm Phillips #PH00 screw using a PH00 screw driver.
    • Remove the two 9.9 mm Phillips #PH00 screws using the PH00 screwdriver.
    Ask FixBot
  7. Canon EOS 60D Rear Cover Removal: step 7, image 1 of 1
    • Using the PH00 screwdriver, remove the 3.8 mm Phillips #PH00 screw located on the back of the camera.
    Ask FixBot
  8. Canon EOS 60D Rear Cover Removal: step 8, image 1 of 2 Canon EOS 60D Rear Cover Removal: step 8, image 2 of 2
    • Using the plastic opening tool, carefully pull up the rubber grip around the port side of the camera.
    • Remove the four different sized screws located beneath the rubber grip.
    • 6 mm Phillips #PH00 screw.
    • 3.4 mm Phillips #PH00 screw.
    • 3.9 mm Phillips #PH00 screw.
    • 2.2 mm Phillips #PH00 screw.
    Ask FixBot
  9. Canon EOS 60D Rear Cover Removal: step 9, image 1 of 2 Canon EOS 60D Rear Cover Removal: step 9, image 2 of 2
    • Using the plastic opening tool, carefully pry off the the side cover.
    Ask FixBot
  10. Canon EOS 60D Rear Cover Removal: step 10, image 1 of 1
    • Remove two 4.8 mm Phillips #PH00 screws from the memory card side of camera using the PH00 screwdriver.
    Ask FixBot
  11. Canon EOS 60D Rear Cover Removal: step 11, image 1 of 1
    • Look at the bottom of the camera so the serial number tag reads up right.
    • Using the PH00 screw driver, remove the top three 3.5 mm Phillips #PH00 screws.
    Ask FixBot
  12. Canon EOS 60D Rear Cover Removal: step 12, image 1 of 1
    • Now gently pull the back cover off the camera.
    • Gently pull the orange wire connected to the motherboard of the camera up and off of the motherboard.
    Ask FixBot
2 other people completed this guide.
Tyler Vaal
761 Reputation
3 Guides authored
USF Tampa, Team 16-6, Wollert Fall 2015 Member of USF Tampa, Team 16-6, Wollert Fall 2015
USFT-WOLLERT-F15S16G6
3 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 29
All Time: 2,989
