Canon EOS 5D Mark IV Top Cover Replacement
  1. Canon EOS 5D Mark IV Top Cover Replacement, Interface Cover: step 1, image 1 of 3 Canon EOS 5D Mark IV Top Cover Replacement, Interface Cover: step 1, image 2 of 3 Canon EOS 5D Mark IV Top Cover Replacement, Interface Cover: step 1, image 3 of 3
    • Before beginning, remove the battery and SD card from the camera.
    • Remove the eyepiece.
    • Using a pair of tweezers, unclip each side of the eyepiece from the bottom while providing light pressure upwards on the eyepiece with your thumb.
    • Remove the battery door.
    • Open the battery door and disengage the hinge spring.
    • While holding the spring back, pull off the battery door.
    Ask FixBot
  2. Canon EOS 5D Mark IV Top Cover Replacement: step 2, image 1 of 3 Canon EOS 5D Mark IV Top Cover Replacement: step 2, image 2 of 3 Canon EOS 5D Mark IV Top Cover Replacement: step 2, image 3 of 3
    • Using a plastic spudger tool, peel off the rubber grip on the left side of the camera.
    • On the Left side of the camera, underneath where the rubber grip was, remove the following screws:
    • Two M1.7x5.0mm Phillips #000 screws.
    • One M1.7x5.0mm Phillips #000 screw.
    • Pry off the plastic interface cover.
    • Use a plastic opening tool if a fingernail doesn't work.
    Ask FixBot
  3. Canon EOS 5D Mark IV Top Cover Replacement, Back Cover: step 3, image 1 of 2 Canon EOS 5D Mark IV Top Cover Replacement, Back Cover: step 3, image 2 of 2
    • With a plastic spudger tool, peel off the rubber grip on the backside of the camera.
    • On the backside of the camera, remove the following screws:
    • Two M1.7x4.5mm JIS #000 screws.
    • Two M1.7x6.0mm JIS #000 screws.
    • One M1.7x9.0 JIS #000 screw.
    • One M1.7x4.5mm Phillips #000 screw.
    Ask FixBot
  4. Canon EOS 5D Mark IV Top Cover Replacement: step 4, image 1 of 3 Canon EOS 5D Mark IV Top Cover Replacement: step 4, image 2 of 3 Canon EOS 5D Mark IV Top Cover Replacement: step 4, image 3 of 3
    • On the bottom of the camera, remove the following screws:
    • Three M1.7x2.5mm JIS #000 screws.
    • Slightly lift up the back cover from the camera, using a plastic spudger or opening tool as needed.
    • Be very careful when lifting the back cover up, there are still two fragile cables attached to it.
    • Carefully pry up the ribbon cable attaching the screen to the main PCB board using a plastic spudger.
    • With the cable disconnected, you can finish lifting off the back cover from the camera.
    Ask FixBot
  5. Canon EOS 5D Mark IV Top Cover Replacement, Front Cover: step 5, image 1 of 2 Canon EOS 5D Mark IV Top Cover Replacement, Front Cover: step 5, image 2 of 2
    • Using a plastic spudger tool, peel off the right rubber grip.
    • On the front of the camera, remove the following screws:
    • Two M1.7x2.8mm Phillips #000 screws.
    • Two M1.7x5.5mm JIS #000 screws.
    • Two M1.7x7.0mm Phillips #000 screws.
    Ask FixBot
  6. Canon EOS 5D Mark IV Top Cover Replacement: step 6, image 1 of 2 Canon EOS 5D Mark IV Top Cover Replacement: step 6, image 2 of 2
    • On the right side of the camera, remove the following screws:
    • Two M1.7x4.0mm Phillips #000 screws.
    • On the bottom of the camera, remove the following screw:
    • One M1.7x5.5mm JIS #000 screw.
    Ask FixBot
  7. Canon EOS 5D Mark IV Top Cover Replacement: step 7, image 1 of 2 Canon EOS 5D Mark IV Top Cover Replacement: step 7, image 2 of 2
    • With a plastic spudger tool, carefully remove the two cables that connects the front cover to the main PCB board.
    • Pull the front cover off the camera body, using a plastic spudger or opening tools as needed.
    • Make sure that neither cable snags on anything as you pull the front cover away from the rest of the camera.
    Ask FixBot
  8. Canon EOS 5D Mark IV Top Cover Replacement, Top Cover: step 8, image 1 of 3 Canon EOS 5D Mark IV Top Cover Replacement, Top Cover: step 8, image 2 of 3 Canon EOS 5D Mark IV Top Cover Replacement, Top Cover: step 8, image 3 of 3
    • Remove the following Screws from the top cover:
    • One M1.7x7.0mm JIS #000 screw.
    • Remove the diopter using a JIS #000 screwdriver.
    Ask FixBot
  9. Canon EOS 5D Mark IV Top Cover Replacement: step 9, image 1 of 3 Canon EOS 5D Mark IV Top Cover Replacement: step 9, image 2 of 3 Canon EOS 5D Mark IV Top Cover Replacement: step 9, image 3 of 3
    • Hold up the plastic cover on the main PCB board.
    • Disconnect the ribbon cable underneath this plastic cover.
    • Using a plastic spudger tool, carefully pry up the brown plastic locking tab.
    • Once the locking tab is lifted up, you can carefully pull out the ribbon cable.
    • There is a hole in the ribbon cable, allowing you to pull the cable out using a tweezer or other pointy tool. Be careful not to damage the ribbon cable.
    • Repeat the steps above to remove the second ribbon cable.
    Ask FixBot
  10. Canon EOS 5D Mark IV Top Cover Replacement: step 10, image 1 of 2 Canon EOS 5D Mark IV Top Cover Replacement: step 10, image 2 of 2
    • On the right side of the PCB board, remove the last ribbon cable that connect the top cover to the main PCB board.
    • Gently pry up on the connector using a plastic spudger tool.
    • With all the ribbon cables disconnected, carefully lift up and remove the top cover from the rest of the camera.
    Ask FixBot
Attached Documents
Zephosk
5,552 Reputation
39 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 40
All Time: 50
