Community-Contributed Guide
Introduction
Go to step 1 ↓This guide will show you how to replace the interface cover, which includes both the plastic cover and the rubber caps over the interface itself.
Note that the Phillips #000 screwdriver is marked as an optional tool as you can always use the JIS #000 screwdriver in its place (JIS screwdrivers won't damage Phillips head screws).
Tools
Spudger4.9
Before beginning, remove the battery and SD card from the camera.
Remove the eyepiece.
Using a pair of tweezers, unclip each side of the eyepiece from the bottom while providing light pressure upwards on the eyepiece with your thumb.
Remove the battery door.
Open the battery door and disengage the hinge spring.
While holding the spring back, pull off the battery door.
Using a plastic spudger tool, peel off the rubber grip on the left side of the camera.
On the Left side of the camera, underneath where the rubber grip was, remove the following screws:
Two M1.7x5.0mm Phillips #000 screws.
One M1.7x5.0mm Phillips #000 screw.
Pry off the plastic interface cover.
