Canon EOS 5D Mark IV Front Cover Replacement
  1. Canon EOS 5D Mark IV Front Cover Replacement, Interface Cover: step 1, image 1 of 3 Canon EOS 5D Mark IV Front Cover Replacement, Interface Cover: step 1, image 2 of 3 Canon EOS 5D Mark IV Front Cover Replacement, Interface Cover: step 1, image 3 of 3
    • Before beginning, remove the battery and SD card from the camera.
    • Remove the eyepiece.
    • Using a pair of tweezers, unclip each side of the eyepiece from the bottom while providing light pressure upwards on the eyepiece with your thumb.
    • Remove the battery door.
    • Open the battery door and disengage the hinge spring.
    • While holding the spring back, pull off the battery door.
    Ask FixBot
  2. Canon EOS 5D Mark IV Front Cover Replacement: step 2, image 1 of 3 Canon EOS 5D Mark IV Front Cover Replacement: step 2, image 2 of 3 Canon EOS 5D Mark IV Front Cover Replacement: step 2, image 3 of 3
    • Using a plastic spudger tool, peel off the rubber grip on the left side of the camera.
    • On the Left side of the camera, underneath where the rubber grip was, remove the following screws:
    • Two M1.7x5.0mm Phillips #000 screws.
    • One M1.7x5.0mm Phillips #000 screw.
    • Pry off the plastic interface cover.
    • Use a plastic opening tool if a fingernail doesn't work.
    Ask FixBot
  3. Canon EOS 5D Mark IV Front Cover Replacement, Back Cover: step 3, image 1 of 2 Canon EOS 5D Mark IV Front Cover Replacement, Back Cover: step 3, image 2 of 2
    • With a plastic spudger tool, peel off the rubber grip on the backside of the camera.
    • On the backside of the camera, remove the following screws:
    • Two M1.7x4.5mm JIS #000 screws.
    • Two M1.7x6.0mm JIS #000 screws.
    • One M1.7x9.0 JIS #000 screw.
    • One M1.7x4.5mm Phillips #000 screw.
    Ask FixBot
  4. Canon EOS 5D Mark IV Front Cover Replacement: step 4, image 1 of 3 Canon EOS 5D Mark IV Front Cover Replacement: step 4, image 2 of 3 Canon EOS 5D Mark IV Front Cover Replacement: step 4, image 3 of 3
    • On the bottom of the camera, remove the following screws:
    • Three M1.7x2.5mm JIS #000 screws.
    • Slightly lift up the back cover from the camera, using a plastic spudger or opening tool as needed.
    • Be very careful when lifting the back cover up, there are still two fragile cables attached to it.
    • Carefully pry up the ribbon cable attaching the screen to the main PCB board using a plastic spudger.
    • With the cable disconnected, you can finish lifting off the back cover from the camera.
    Ask FixBot
  5. Canon EOS 5D Mark IV Front Cover Replacement, Front Cover: step 5, image 1 of 2 Canon EOS 5D Mark IV Front Cover Replacement, Front Cover: step 5, image 2 of 2
    • Using a plastic spudger tool, peel off the right rubber grip.
    • On the front of the camera, remove the following screws:
    • Two M1.7x2.8mm Phillips #000 screws.
    • Two M1.7x5.5mm JIS #000 screws.
    • Two M1.7x7.0mm Phillips #000 screws.
    Ask FixBot
  6. Canon EOS 5D Mark IV Front Cover Replacement: step 6, image 1 of 2 Canon EOS 5D Mark IV Front Cover Replacement: step 6, image 2 of 2
    • On the right side of the camera, remove the following screws:
    • Two M1.7x4.0mm Phillips #000 screws.
    • On the bottom of the camera, remove the following screw:
    • One M1.7x5.5mm JIS #000 screw.
    Ask FixBot
  7. Canon EOS 5D Mark IV Front Cover Replacement: step 7, image 1 of 2 Canon EOS 5D Mark IV Front Cover Replacement: step 7, image 2 of 2
    • With a plastic spudger tool, carefully remove the two cables that connects the front cover to the main PCB board.
    • Pull the front cover off the camera body, using a plastic spudger or opening tools as needed.
    • Make sure that neither cable snags on anything as you pull the front cover away from the rest of the camera.
    Ask FixBot
Attached Documents
Zephosk
6,036 Reputation
39 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 39
All Time: 98
