Canon EOS 5D Mark II Top Panel Replacement
Views: 16K
View statistics:
Past 24 Hours:
4
Past 7 Days:
45
Past 30 Days:
209
All Time:
16,411
Comments: 22
9 comments on steps, 13 guide comments.
Go to guide comments
Completed: 15
15 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 - 35 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will show users how to replace the top panel and access many internal parts such as the viewfinder and shutter assembly.
Tools
    1. Canon EOS 5D Mark II Top Panel Replacement, Clock Battery: step 1, image 1 of 1
      • Lift the rubber flap covering the input/output jacks.
      Ask FixBot
    2. Canon EOS 5D Mark II Top Panel Replacement: step 2, image 1 of 1
      • Using a Phillips #000, remove the single 3.4 mm screw.
      Ask FixBot
    3. Canon EOS 5D Mark II Top Panel Replacement: step 3, image 1 of 1
      • This step will permanently erase all user settings.
      • The memory battery can now be easily slid out of place.
      • If you are following this guide in an effort to perform a hard reset, you should now press the shutter button multiple times in order to drain any left over power, then replace the batteries and power the device back on. You have just performed a hard reset!
      Ask FixBot
    1. Canon EOS 5D Mark II Top Panel Replacement, Back Panel: step 4, image 1 of 1
      • Peel back the rubber cover above the in/out ports to reveal two screw heads.
      Ask FixBot
    2. Canon EOS 5D Mark II Top Panel Replacement: step 5, image 1 of 1
      • Remove both 5.4 mm screws using a Phillips #0.
      Ask FixBot
    3. Canon EOS 5D Mark II Top Panel Replacement: step 6, image 1 of 1
      • Lift the in/out port plastic covering from the bottom where the backup battery used to be.
      Ask FixBot
    4. Canon EOS 5D Mark II Top Panel Replacement: step 7, image 1 of 1
      • Remove each 6.3 mm screw on either side of the viewfinder using a Phillips #0 screwdriver.
      Ask FixBot
    5. Canon EOS 5D Mark II Top Panel Replacement: step 8, image 1 of 1
      • Remove the three 4.8 mm screws on the bottom of the back plate using a Phillips #0.
      Ask FixBot
    6. Canon EOS 5D Mark II Top Panel Replacement: step 9, image 1 of 1
      • Peel back the rubber covering next to the menu dial to access the screw.
      • Remove the single 3.4 mm screw using a Phillips #0.
      Ask FixBot
    7. Canon EOS 5D Mark II Top Panel Replacement: step 10, image 1 of 1
      • The back panel can now fall off easily by turning the device upside down. Be sure to catch it so the data ribbons do not tear or tug.
      Ask FixBot
    8. Canon EOS 5D Mark II Top Panel Replacement: step 11, image 1 of 1
      • Remove each data ribbon cable from the motherboard by applying pressure down towards the motherboard and gently sliding your thumb upwards on the slot where the cable meets the motherboard. This will raise a very small clip that locks the cable in place.
      • The back panel is now free from the rest of the device.
      Ask FixBot
    1. Canon EOS 5D Mark II Top Panel Replacement, Front Panel: step 12, image 1 of 1
      Tool used on this step:
      Buy
      • Using tweezers, pull out the wire attaching the front panel to the motherboard.
      Ask FixBot
    2. Canon EOS 5D Mark II Top Panel Replacement: step 13, image 1 of 1
      • Peel off the rubber cover on the front panel in order to access the screws underneath.
      Ask FixBot
    3. Canon EOS 5D Mark II Top Panel Replacement: step 14, image 1 of 1
      • Remove each of the 4.9 mm three screws using a Phillips #0.
      Ask FixBot
    4. Canon EOS 5D Mark II Top Panel Replacement: step 15, image 1 of 1
      • Remove the two 4.8 mm screws above where the lens would be using a Phillips #0.
      Ask FixBot
    5. Canon EOS 5D Mark II Top Panel Replacement: step 16, image 1 of 1
      • Remove the single screw underneath where the lens would be using a Phillips #0.
      Ask FixBot
    6. Canon EOS 5D Mark II Top Panel Replacement: step 17, image 1 of 3 Canon EOS 5D Mark II Top Panel Replacement: step 17, image 2 of 3 Canon EOS 5D Mark II Top Panel Replacement: step 17, image 3 of 3
      • Remove the four 3.0 mm screws next to the memory card reader using a Phillips #0.
      Ask FixBot
    7. Canon EOS 5D Mark II Top Panel Replacement: step 18, image 1 of 2 Canon EOS 5D Mark II Top Panel Replacement: step 18, image 2 of 2
      • Remove the front panel by lifting upwards from the right side where the in/out ports used to be.
      Ask FixBot
    1. Canon EOS 5D Mark II Top Panel Replacement, Top Panel: step 19, image 1 of 1
      • Remove the single 5.9 mm screw next to the the strap loop on the same side as the shutter button.
      Ask FixBot
    2. Canon EOS 5D Mark II Top Panel Replacement: step 20, image 1 of 1
      • Remove the single 3.8 mm screw underneath the camera strap on the same side as the in/out ports.
      • If you are having problems finding this screw, note the orientation of the viewfinder in the bottom center of the photo.
      Ask FixBot
    3. Canon EOS 5D Mark II Top Panel Replacement: step 21, image 1 of 2 Canon EOS 5D Mark II Top Panel Replacement: step 21, image 2 of 2
      Buy
      • Using tweezers or your thumb, raise the clasp holding the topmost data ribbon cable in order to release it.
      Ask FixBot
    4. Canon EOS 5D Mark II Top Panel Replacement: step 22, image 1 of 1
      • The top panel is now free from the rest of the device. Lift to remove.
      Ask FixBot
15 other people completed this guide.
Mike Seed
3,190 Reputation
8 Guides authored
USF Tampa, Team 1-6, Hickman Fall 2014 Member of USF Tampa, Team 1-6, Hickman Fall 2014
USFT-HICKMAN-F14S1G6
3 Members
96 Guides authored
13 Guide Comments
The strap hook on the left side of my 5d2 body got bent in a fall and I want to replace it. Do I have to go through all these steps or is there an easier way to get to it ? Thanks
Tim - Reply Share
Everything it's very nice in this guide.
I just have a question?
Where do I can find the top panel to buy it?
It's seem almost impossible...
stefano masetti - Reply Share
I would also like to know where a replacement top panel can be purchased from.
t1000email - Reply Share
I purchased one on Ebay , (US) $100 USD
yanhao996 - Reply Share
The guide is useful and quite easy to follow. Thanks
Janes - Reply Share
Past 24 Hours: 4
Past 7 Days: 45
Past 30 Days: 209
All Time: 16,411
