Canon EOS 40D Flash Hot Shoe Replacement
  1. Canon EOS 40D Flash Hot Shoe Replacement, Battery: step 1, image 1 of 1
    • Locate the battery compartment cover on the bottom of the camera below the shutter button.
    Ask FixBot
  2. Canon EOS 40D Flash Hot Shoe Replacement: step 2, image 1 of 1
    • Find the marked arrow on the battery compartment cover labeled "BATT. OPEN". Slide the lever following the arrow's direction and lift at the same time to release the latch.
    Ask FixBot
  3. Canon EOS 40D Flash Hot Shoe Replacement: step 3, image 1 of 1
    • Release the lever and allow the battery compartment cover to completely open.
    • Remove the battery.
    Ask FixBot
  4. Canon EOS 40D Flash Hot Shoe Replacement, Flash Hot Shoe: step 4, image 1 of 3 Canon EOS 40D Flash Hot Shoe Replacement, Flash Hot Shoe: step 4, image 2 of 3 Canon EOS 40D Flash Hot Shoe Replacement, Flash Hot Shoe: step 4, image 3 of 3
    • Use a metal spudger or opening tool to gently lift the hotshoe plate and slide it off.
    Ask FixBot
  5. Canon EOS 40D Flash Hot Shoe Replacement: step 5, image 1 of 3 Canon EOS 40D Flash Hot Shoe Replacement: step 5, image 2 of 3 Canon EOS 40D Flash Hot Shoe Replacement: step 5, image 3 of 3
    • Remove the four 4.0 mm Phillips #000 screws securing the flash shoe to the camera.
    • Remove the flash shoe.
    Ask FixBot
4 other people completed this guide.
Sarah de Freitas
277 Reputation
1 Guide authored
USF Tampa, Team 12-3, Blackwell Fall 2015 Member of USF Tampa, Team 12-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G3
4 Members
16 Guides authored
1 Guide Comment
This is the best down to earth instructions i have ever had. No messing about even tells what screws and how to open the battery cover
Albert
albert irving - Reply Share
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 71
All Time: 5,629
