Canon EOS 300 Side Panel with Grip Replacement
    1. Canon EOS 300 Side Panel with Grip Replacement, Batteries: step 1, image 1 of 3 Canon EOS 300 Side Panel with Grip Replacement, Batteries: step 1, image 2 of 3 Canon EOS 300 Side Panel with Grip Replacement, Batteries: step 1, image 3 of 3
      • Open up the battery door.
      Ask FixBot
    2. Canon EOS 300 Side Panel with Grip Replacement: step 2, image 1 of 2 Canon EOS 300 Side Panel with Grip Replacement: step 2, image 2 of 2
      • Remove the batteries from the camera by sliding them out into your palm.
      Ask FixBot
    1. Canon EOS 300 Side Panel with Grip Replacement, Side Panel with Lever: step 3, image 1 of 2 Canon EOS 300 Side Panel with Grip Replacement, Side Panel with Lever: step 3, image 2 of 2
      • Release the side latch to open the back panel.
      Ask FixBot
    2. Canon EOS 300 Side Panel with Grip Replacement: step 4, image 1 of 2 Canon EOS 300 Side Panel with Grip Replacement: step 4, image 2 of 2
      • Remove the two black 4.5mm screws above and below the latch.
      Ask FixBot
    3. Canon EOS 300 Side Panel with Grip Replacement: step 5, image 1 of 2 Canon EOS 300 Side Panel with Grip Replacement: step 5, image 2 of 2
      • Using your finger, carefully pry open the side panel from the top of camera.
      • Pull panel downwards to remove.
      • Make sure to keep track of the small black piece of rubber under the latch.
      Ask FixBot
    1. Canon EOS 300 Side Panel with Grip Replacement, Front Panel: step 6, image 1 of 2 Canon EOS 300 Side Panel with Grip Replacement, Front Panel: step 6, image 2 of 2
      • Remove the two silver 6mm Phillips #1 screws.
      Ask FixBot
    2. Canon EOS 300 Side Panel with Grip Replacement: step 7, image 1 of 2 Canon EOS 300 Side Panel with Grip Replacement: step 7, image 2 of 2
      • Flip camera over to the bottom.
      • Remove the one 5mm Phillips #1 silver screw.
      Ask FixBot
    3. Canon EOS 300 Side Panel with Grip Replacement: step 8, image 1 of 2 Canon EOS 300 Side Panel with Grip Replacement: step 8, image 2 of 2
      • Remove the front panel by pulling away from the side with the lever.
      Ask FixBot
    1. Canon EOS 300 Side Panel with Grip Replacement, Bottom Panel: step 9, image 1 of 2 Canon EOS 300 Side Panel with Grip Replacement, Bottom Panel: step 9, image 2 of 2
      • Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
      • Remove five black 4.8mm Phillips #1 screws.
      Ask FixBot
    2. Canon EOS 300 Side Panel with Grip Replacement: step 10, image 1 of 3 Canon EOS 300 Side Panel with Grip Replacement: step 10, image 2 of 3 Canon EOS 300 Side Panel with Grip Replacement: step 10, image 3 of 3
      • Simply remove the bottom panel by prying it off with your finger.
      • When removing the panel, be sure the bottom of the camera is facing upright. There are loose gears that may fall out.
      • Be wary of a loose piece of foam attached to the bottom panel.
      Ask FixBot
    1. Canon EOS 300 Side Panel with Grip Replacement, Side Panel with Grip: step 11, image 1 of 3 Canon EOS 300 Side Panel with Grip Replacement, Side Panel with Grip: step 11, image 2 of 3 Canon EOS 300 Side Panel with Grip Replacement, Side Panel with Grip: step 11, image 3 of 3
      • Remove the remote control socket cover.
      Ask FixBot
    2. Canon EOS 300 Side Panel with Grip Replacement: step 12, image 1 of 2 Canon EOS 300 Side Panel with Grip Replacement: step 12, image 2 of 2
      • Remove two black 4.5mm Phillips #1 screws.
      Ask FixBot
    3. Canon EOS 300 Side Panel with Grip Replacement: step 13, image 1 of 2 Canon EOS 300 Side Panel with Grip Replacement: step 13, image 2 of 2
      • Remove two black 4.8mm Phillips #1 screws on the front of the camera.
      Ask FixBot
    4. Canon EOS 300 Side Panel with Grip Replacement: step 14, image 1 of 2 Canon EOS 300 Side Panel with Grip Replacement: step 14, image 2 of 2
      • Pry open the side grip using a spudger.
      Ask FixBot
Jordan Tang
608 Reputation
5 Guides authored
Cal Poly, Team 6-20, Maness Winter 2014 Member of Cal Poly, Team 6-20, Maness Winter 2014
CPSU-MANESS-W14S6G20
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 46
All Time: 2,023
