Up to 20% off select tools
Canon EOS 300 Front Panel Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
23
Past 30 Days:
100
All Time:
1,841
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The front panel will be removed in order to access other areas of the camera such as the battery door and top panel
    1. Canon EOS 300 Front Panel Replacement, Batteries: step 1, image 1 of 3 Canon EOS 300 Front Panel Replacement, Batteries: step 1, image 2 of 3 Canon EOS 300 Front Panel Replacement, Batteries: step 1, image 3 of 3
      • Open up the battery door.
      Ask FixBot
    2. Canon EOS 300 Front Panel Replacement: step 2, image 1 of 2 Canon EOS 300 Front Panel Replacement: step 2, image 2 of 2
      • Remove the batteries from the camera by sliding them out into your palm.
      Ask FixBot
    1. Canon EOS 300 Front Panel Replacement, Side Panel with Lever: step 3, image 1 of 2 Canon EOS 300 Front Panel Replacement, Side Panel with Lever: step 3, image 2 of 2
      • Release the side latch to open the back panel.
      Ask FixBot
    2. Canon EOS 300 Front Panel Replacement: step 4, image 1 of 2 Canon EOS 300 Front Panel Replacement: step 4, image 2 of 2
      • Remove the two black 4.5mm screws above and below the latch.
      Ask FixBot
    3. Canon EOS 300 Front Panel Replacement: step 5, image 1 of 2 Canon EOS 300 Front Panel Replacement: step 5, image 2 of 2
      • Using your finger, carefully pry open the side panel from the top of camera.
      • Pull panel downwards to remove.
      • Make sure to keep track of the small black piece of rubber under the latch.
      Ask FixBot
    1. Canon EOS 300 Front Panel Replacement, Front Panel: step 6, image 1 of 2 Canon EOS 300 Front Panel Replacement, Front Panel: step 6, image 2 of 2
      • Remove the two silver 6mm Phillips #1 screws.
      Ask FixBot
    2. Canon EOS 300 Front Panel Replacement: step 7, image 1 of 2 Canon EOS 300 Front Panel Replacement: step 7, image 2 of 2
      • Flip camera over to the bottom.
      • Remove the one 5mm Phillips #1 silver screw.
      Ask FixBot
    3. Canon EOS 300 Front Panel Replacement: step 8, image 1 of 2 Canon EOS 300 Front Panel Replacement: step 8, image 2 of 2
      • Remove the front panel by pulling away from the side with the lever.
      Ask FixBot
Author
with
Jordan Tang
608 Reputation
5 Guides authored
Cal Poly, Team 6-20, Maness Winter 2014 Member of Cal Poly, Team 6-20, Maness Winter 2014
CPSU-MANESS-W14S6G20
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 100
All Time: 1,841
