Up to 20% off select tools
Canon EOS 300 Command Dial Replacement
Views: 2.8K
View statistics:
Past 24 Hours:
6
Past 7 Days:
21
Past 30 Days:
110
All Time:
2,783
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Use this guide to replace your camera's command dial.
    1. Canon EOS 300 Command Dial Replacement, Batteries: step 1, image 1 of 3 Canon EOS 300 Command Dial Replacement, Batteries: step 1, image 2 of 3 Canon EOS 300 Command Dial Replacement, Batteries: step 1, image 3 of 3
      • Open up the battery door.
      Ask FixBot
    2. Canon EOS 300 Command Dial Replacement: step 2, image 1 of 2 Canon EOS 300 Command Dial Replacement: step 2, image 2 of 2
      • Remove the batteries from the camera by sliding them out into your palm.
      Ask FixBot
    1. Canon EOS 300 Command Dial Replacement, Side Panel with Lever: step 3, image 1 of 2 Canon EOS 300 Command Dial Replacement, Side Panel with Lever: step 3, image 2 of 2
      • Release the side latch to open the back panel.
      Ask FixBot
    2. Canon EOS 300 Command Dial Replacement: step 4, image 1 of 2 Canon EOS 300 Command Dial Replacement: step 4, image 2 of 2
      • Remove the two black 4.5mm screws above and below the latch.
      Ask FixBot
    3. Canon EOS 300 Command Dial Replacement: step 5, image 1 of 2 Canon EOS 300 Command Dial Replacement: step 5, image 2 of 2
      • Using your finger, carefully pry open the side panel from the top of camera.
      • Pull panel downwards to remove.
      • Make sure to keep track of the small black piece of rubber under the latch.
      Ask FixBot
    1. Canon EOS 300 Command Dial Replacement, Front Panel: step 6, image 1 of 2 Canon EOS 300 Command Dial Replacement, Front Panel: step 6, image 2 of 2
      • Remove the two silver 6mm Phillips #1 screws.
      Ask FixBot
    2. Canon EOS 300 Command Dial Replacement: step 7, image 1 of 2 Canon EOS 300 Command Dial Replacement: step 7, image 2 of 2
      • Flip camera over to the bottom.
      • Remove the one 5mm Phillips #1 silver screw.
      Ask FixBot
    3. Canon EOS 300 Command Dial Replacement: step 8, image 1 of 2 Canon EOS 300 Command Dial Replacement: step 8, image 2 of 2
      • Remove the front panel by pulling away from the side with the lever.
      Ask FixBot
    1. Canon EOS 300 Command Dial Replacement, Bottom Panel: step 9, image 1 of 2 Canon EOS 300 Command Dial Replacement, Bottom Panel: step 9, image 2 of 2
      • Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
      • Remove five black 4.8mm Phillips #1 screws.
      Ask FixBot
    2. Canon EOS 300 Command Dial Replacement: step 10, image 1 of 3 Canon EOS 300 Command Dial Replacement: step 10, image 2 of 3 Canon EOS 300 Command Dial Replacement: step 10, image 3 of 3
      • Simply remove the bottom panel by prying it off with your finger.
      • When removing the panel, be sure the bottom of the camera is facing upright. There are loose gears that may fall out.
      • Be wary of a loose piece of foam attached to the bottom panel.
      Ask FixBot
    1. Canon EOS 300 Command Dial Replacement, Side Panel with Grip: step 11, image 1 of 3 Canon EOS 300 Command Dial Replacement, Side Panel with Grip: step 11, image 2 of 3 Canon EOS 300 Command Dial Replacement, Side Panel with Grip: step 11, image 3 of 3
      • Remove the remote control socket cover.
      Ask FixBot
    2. Canon EOS 300 Command Dial Replacement: step 12, image 1 of 2 Canon EOS 300 Command Dial Replacement: step 12, image 2 of 2
      • Remove two black 4.5mm Phillips #1 screws.
      Ask FixBot
    3. Canon EOS 300 Command Dial Replacement: step 13, image 1 of 2 Canon EOS 300 Command Dial Replacement: step 13, image 2 of 2
      • Remove two black 4.8mm Phillips #1 screws on the front of the camera.
      Ask FixBot
    4. Canon EOS 300 Command Dial Replacement: step 14, image 1 of 2 Canon EOS 300 Command Dial Replacement: step 14, image 2 of 2
      • Pry open the side grip using a spudger.
      Ask FixBot
    1. Canon EOS 300 Command Dial Replacement, Eyecup: step 15, image 1 of 2 Canon EOS 300 Command Dial Replacement, Eyecup: step 15, image 2 of 2
      • With your hands, remove the rubber grip from the eye piece.
      Ask FixBot
    2. Canon EOS 300 Command Dial Replacement: step 16, image 1 of 1
      • Remove the eyecup from the eyepiece by pushing the eyecup up.
      Ask FixBot
    1. Canon EOS 300 Command Dial Replacement, Top Panel: step 17, image 1 of 2 Canon EOS 300 Command Dial Replacement, Top Panel: step 17, image 2 of 2
      • Remove two silver 5.0mm Phillips #1 screws.
      Ask FixBot
    2. Canon EOS 300 Command Dial Replacement: step 18, image 1 of 1
      • Remove the silver 5.5mm Phillips #1 screw.
      Ask FixBot
    3. Canon EOS 300 Command Dial Replacement: step 19, image 1 of 2 Canon EOS 300 Command Dial Replacement: step 19, image 2 of 2
      • Pry the top silver part of the camera off.
      • Buttons may slip out of the camera's top as the top is pulled off the camera (shown in picture two).
      Ask FixBot
    1. Canon EOS 300 Command Dial Replacement, Command Dial: step 20, image 1 of 3 Canon EOS 300 Command Dial Replacement, Command Dial: step 20, image 2 of 3 Canon EOS 300 Command Dial Replacement, Command Dial: step 20, image 3 of 3
      • On the top panel, remove the silver 3.8mm Phillips #1 screw right below the command dial.
      • A small metal piece will come off with the screw.
      Ask FixBot
Author
with
Tammy Kong
805 Reputation
6 Guides authored
Cal Poly, Team 6-20, Maness Winter 2014 Member of Cal Poly, Team 6-20, Maness Winter 2014
CPSU-MANESS-W14S6G20
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 21
Past 30 Days: 110
All Time: 2,783
