Canon EOS 300 Battery Door Replacement
  1. Canon EOS 300 Battery Door Replacement, Batteries: step 1, image 1 of 3 Canon EOS 300 Battery Door Replacement, Batteries: step 1, image 2 of 3 Canon EOS 300 Battery Door Replacement, Batteries: step 1, image 3 of 3
    • Open up the battery door.
    Ask FixBot
  2. Canon EOS 300 Battery Door Replacement: step 2, image 1 of 2 Canon EOS 300 Battery Door Replacement: step 2, image 2 of 2
    • Remove the batteries from the camera by sliding them out into your palm.
    Ask FixBot
  3. Canon EOS 300 Battery Door Replacement, Side Panel with Lever: step 3, image 1 of 2 Canon EOS 300 Battery Door Replacement, Side Panel with Lever: step 3, image 2 of 2
    • Release the side latch to open the back panel.
    Ask FixBot
  4. Canon EOS 300 Battery Door Replacement: step 4, image 1 of 2 Canon EOS 300 Battery Door Replacement: step 4, image 2 of 2
    • Remove the two black 4.5mm screws above and below the latch.
    Ask FixBot
  5. Canon EOS 300 Battery Door Replacement: step 5, image 1 of 2 Canon EOS 300 Battery Door Replacement: step 5, image 2 of 2
    • Using your finger, carefully pry open the side panel from the top of camera.
    • Pull panel downwards to remove.
    • Make sure to keep track of the small black piece of rubber under the latch.
    Ask FixBot
  6. Canon EOS 300 Battery Door Replacement, Front Panel: step 6, image 1 of 2 Canon EOS 300 Battery Door Replacement, Front Panel: step 6, image 2 of 2
    • Remove the two silver 6mm Phillips #1 screws.
    Ask FixBot
  7. Canon EOS 300 Battery Door Replacement: step 7, image 1 of 2 Canon EOS 300 Battery Door Replacement: step 7, image 2 of 2
    • Flip camera over to the bottom.
    • Remove the one 5mm Phillips #1 silver screw.
    Ask FixBot
  8. Canon EOS 300 Battery Door Replacement: step 8, image 1 of 2 Canon EOS 300 Battery Door Replacement: step 8, image 2 of 2
    • Remove the front panel by pulling away from the side with the lever.
    Ask FixBot
  9. Canon EOS 300 Battery Door Replacement, Bottom Panel: step 9, image 1 of 2 Canon EOS 300 Battery Door Replacement, Bottom Panel: step 9, image 2 of 2
    • Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
    • Remove five black 4.8mm Phillips #1 screws.
    Ask FixBot
  10. Canon EOS 300 Battery Door Replacement: step 10, image 1 of 3 Canon EOS 300 Battery Door Replacement: step 10, image 2 of 3 Canon EOS 300 Battery Door Replacement: step 10, image 3 of 3
    • Simply remove the bottom panel by prying it off with your finger.
    • When removing the panel, be sure the bottom of the camera is facing upright. There are loose gears that may fall out.
    • Be wary of a loose piece of foam attached to the bottom panel.
    Ask FixBot
  11. Canon EOS 300 Battery Door Replacement, Side Panel with Grip: step 11, image 1 of 3 Canon EOS 300 Battery Door Replacement, Side Panel with Grip: step 11, image 2 of 3 Canon EOS 300 Battery Door Replacement, Side Panel with Grip: step 11, image 3 of 3
    • Remove the remote control socket cover.
    Ask FixBot
  12. Canon EOS 300 Battery Door Replacement: step 12, image 1 of 2 Canon EOS 300 Battery Door Replacement: step 12, image 2 of 2
    • Remove two black 4.5mm Phillips #1 screws.
    Ask FixBot
  13. Canon EOS 300 Battery Door Replacement: step 13, image 1 of 2 Canon EOS 300 Battery Door Replacement: step 13, image 2 of 2
    • Remove two black 4.8mm Phillips #1 screws on the front of the camera.
    Ask FixBot
  14. Canon EOS 300 Battery Door Replacement: step 14, image 1 of 2 Canon EOS 300 Battery Door Replacement: step 14, image 2 of 2
    • Pry open the side grip using a spudger.
    Ask FixBot
  15. Canon EOS 300 Battery Door Replacement, Battery Door: step 15, image 1 of 3 Canon EOS 300 Battery Door Replacement, Battery Door: step 15, image 2 of 3 Canon EOS 300 Battery Door Replacement, Battery Door: step 15, image 3 of 3
    • Remove one black 5mm Phillips #1 screw.
    Ask FixBot
4 other people completed this guide.
Jordan Tang
608 Reputation
5 Guides authored
Cal Poly, Team 6-20, Maness Winter 2014 Member of Cal Poly, Team 6-20, Maness Winter 2014
CPSU-MANESS-W14S6G20
4 Members
32 Guides authored
3 Guide Comments
When reassembling, make sure to attach the spring shown in step 8 to the film back release mechanism. I missed this the first time I reassembled the camera and the release/close slide would not automatically close like it did before. I found keeping a finger over the bottom post and using the SIM removal bit to stretch the spring to the top of the slide was very useful. Overall great guide! Thanks for posting!
Cody Mull - Reply Share
would there be a way to do it faster? i just need to attach a battery grip and am not comfortable with taking the whole camera apart just to unscrew 1 screw
sillyfy cz - Reply Share
Thank you for this support.
Where can I find a new battery cover for the Canon EOS 300?
Mine is broken;
Do you have a website, please?
Best regards
Pierre-Yves Estors - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 57
All Time: 3,196
