Canon EOS 300 Back Lock-Release Lever Replacement
    1. Canon EOS 300 Back Lock-Release Lever Replacement, Batteries: step 1, image 1 of 3 Canon EOS 300 Back Lock-Release Lever Replacement, Batteries: step 1, image 2 of 3 Canon EOS 300 Back Lock-Release Lever Replacement, Batteries: step 1, image 3 of 3
      • Open up the battery door.
      Ask FixBot
    2. Canon EOS 300 Back Lock-Release Lever Replacement: step 2, image 1 of 2 Canon EOS 300 Back Lock-Release Lever Replacement: step 2, image 2 of 2
      • Remove the batteries from the camera by sliding them out into your palm.
      Ask FixBot
    1. Canon EOS 300 Back Lock-Release Lever Replacement, Side Panel with Lever: step 3, image 1 of 2 Canon EOS 300 Back Lock-Release Lever Replacement, Side Panel with Lever: step 3, image 2 of 2
      • Release the side latch to open the back panel.
      Ask FixBot
    2. Canon EOS 300 Back Lock-Release Lever Replacement: step 4, image 1 of 2 Canon EOS 300 Back Lock-Release Lever Replacement: step 4, image 2 of 2
      • Remove the two black 4.5mm screws above and below the latch.
      Ask FixBot
    3. Canon EOS 300 Back Lock-Release Lever Replacement: step 5, image 1 of 2 Canon EOS 300 Back Lock-Release Lever Replacement: step 5, image 2 of 2
      • Using your finger, carefully pry open the side panel from the top of camera.
      • Pull panel downwards to remove.
      • Make sure to keep track of the small black piece of rubber under the latch.
      Ask FixBot
    1. Canon EOS 300 Back Lock-Release Lever Replacement, Front Panel: step 6, image 1 of 2 Canon EOS 300 Back Lock-Release Lever Replacement, Front Panel: step 6, image 2 of 2
      • Remove the two silver 6mm Phillips #1 screws.
      Ask FixBot
    2. Canon EOS 300 Back Lock-Release Lever Replacement: step 7, image 1 of 2 Canon EOS 300 Back Lock-Release Lever Replacement: step 7, image 2 of 2
      • Flip camera over to the bottom.
      • Remove the one 5mm Phillips #1 silver screw.
      Ask FixBot
    3. Canon EOS 300 Back Lock-Release Lever Replacement: step 8, image 1 of 2 Canon EOS 300 Back Lock-Release Lever Replacement: step 8, image 2 of 2
      • Remove the front panel by pulling away from the side with the lever.
      Ask FixBot
    1. Canon EOS 300 Back Lock-Release Lever Replacement, Back Lock-Release Lever: step 9, image 1 of 3 Canon EOS 300 Back Lock-Release Lever Replacement, Back Lock-Release Lever: step 9, image 2 of 3 Canon EOS 300 Back Lock-Release Lever Replacement, Back Lock-Release Lever: step 9, image 3 of 3
      • Pull off the lever by pushing up from the bottom and pulling away from the bottom.
      Ask FixBot
2 other people completed this guide.
Jordan Tang
608 Reputation
5 Guides authored
Cal Poly, Team 6-20, Maness Winter 2014 Member of Cal Poly, Team 6-20, Maness Winter 2014
CPSU-MANESS-W14S6G20
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 60
All Time: 2,805
