Canon EOS 30 Lens Mount Rings
  1. Canon EOS 30 Lens Mount Rings, Front Panel: step 1, image 1 of 1
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
    Ask FixBot
  2. Canon EOS 30 Lens Mount Rings: step 2, image 1 of 1
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
    Ask FixBot
  3. Canon EOS 30 Lens Mount Rings: step 3, image 1 of 1
    • Remove the 4.8 mm black screw on the left side of the camera.
    Ask FixBot
  4. Canon EOS 30 Lens Mount Rings: step 4, image 1 of 1
    • Remove the front panel by lifting it away from the camera's body.
    Ask FixBot
  5. Canon EOS 30 Lens Mount Rings, Lens Mount Rings: step 5, image 1 of 1
    • Remove four 7.1 mm silver screws from lens mount ring.
    Ask FixBot
  6. Canon EOS 30 Lens Mount Rings: step 6, image 1 of 1
    • Remove outer mount ring.
    • The silver button may detach.
    Ask FixBot
  7. Canon EOS 30 Lens Mount Rings: step 7, image 1 of 1
    • Remove thin gold ring.
    • Correct orientation is pictured.
    Ask FixBot
  8. Canon EOS 30 Lens Mount Rings: step 8, image 1 of 1
    • Remove thin silver ring.
    Ask FixBot
Antonia
124 Reputation
2 Guides authored
Cal Poly, Team 8-8, Regan Spring 2011 Member of Cal Poly, Team 8-8, Regan Spring 2011
CPSU-REGAN-S11S8G8
5 Members
22 Guides authored
1 Guide Comment
Very handy. One addition though - the silver button lever is on the wrong side - it is not facing the mirror box but the plastic lens release button. Plus, you are missing the fact that there is a spring underneatch the silver leaver which keeps the mount pin coming back up.
Patryk Granatowicz - Reply Share
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 55
All Time: 6,243
