Up to 20% off select tools
Canon ELPH Z3 Camera Shutter Button Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
7
Past 30 Days:
35
All Time:
809
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The shutter button is one of the most important components of a camera. The shutter button is the button one would press in order to take a picture. It is not uncommon for issues to arise with shutter buttons because they are heavily used. Any issues ranging from dirt build up or a connection malfunction. This easy to follow guide will show you how to gain access to the shutter button for cleaning and how to fully replace the shutter button for the Canon ELPH Z3.
    1. Canon ELPH Z3 Camera Shutter Button Replacement, Shutter Button: step 1, image 1 of 3 Canon ELPH Z3 Camera Shutter Button Replacement, Shutter Button: step 1, image 2 of 3 Canon ELPH Z3 Camera Shutter Button Replacement, Shutter Button: step 1, image 3 of 3
      • Unscrew the 7 4.1mm screws around the camera using a PH000 screwdriver.
      Ask FixBot
    2. Canon ELPH Z3 Camera Shutter Button Replacement: step 2, image 1 of 3 Canon ELPH Z3 Camera Shutter Button Replacement: step 2, image 2 of 3 Canon ELPH Z3 Camera Shutter Button Replacement: step 2, image 3 of 3
      • Split the front and back coverings of the camera.
      • Remove the back covering completely.
      • This allows for easier access to the shutter button carrier.
      Ask FixBot
    3. Canon ELPH Z3 Camera Shutter Button Replacement: step 3, image 1 of 2 Canon ELPH Z3 Camera Shutter Button Replacement: step 3, image 2 of 2
      • Slide the shutter button carrier off of the camera.
      • Notice shutter button is on the right hand side of the carrier.
      Ask FixBot
    4. Canon ELPH Z3 Camera Shutter Button Replacement: step 4, image 1 of 3 Canon ELPH Z3 Camera Shutter Button Replacement: step 4, image 2 of 3 Canon ELPH Z3 Camera Shutter Button Replacement: step 4, image 3 of 3
      • Press upward on the shutter button from the underside of the carrier by using your thumb.
      • Separate the shutter button from the carrier.
      Ask FixBot
Author
with
Nathan Barros
1 Reputation
3 Guides authored
UMass Dartmouth, Team 1-7, Catania Fall 2016 Member of UMass Dartmouth, Team 1-7, Catania Fall 2016
UMASSD-CATANIA-F16S1G7
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 35
All Time: 809
