Canon ELPH Z3 Camera Rear Screen Replacement
    1. Canon ELPH Z3 Camera Rear Screen Replacement, Shutter Button: step 1, image 1 of 3 Canon ELPH Z3 Camera Rear Screen Replacement, Shutter Button: step 1, image 2 of 3 Canon ELPH Z3 Camera Rear Screen Replacement, Shutter Button: step 1, image 3 of 3
      • Unscrew the 7 4.1mm screws around the camera using a PH000 screwdriver.
      Ask FixBot
    2. Canon ELPH Z3 Camera Rear Screen Replacement: step 2, image 1 of 3 Canon ELPH Z3 Camera Rear Screen Replacement: step 2, image 2 of 3 Canon ELPH Z3 Camera Rear Screen Replacement: step 2, image 3 of 3
      • Split the front and back coverings of the camera.
      • Remove the back covering completely.
      • This allows for easier access to the shutter button carrier.
      Ask FixBot
    3. Canon ELPH Z3 Camera Rear Screen Replacement: step 3, image 1 of 2 Canon ELPH Z3 Camera Rear Screen Replacement: step 3, image 2 of 2
      • Slide the shutter button carrier off of the camera.
      • Notice shutter button is on the right hand side of the carrier.
      Ask FixBot
    4. Canon ELPH Z3 Camera Rear Screen Replacement: step 4, image 1 of 3 Canon ELPH Z3 Camera Rear Screen Replacement: step 4, image 2 of 3 Canon ELPH Z3 Camera Rear Screen Replacement: step 4, image 3 of 3
      • Press upward on the shutter button from the underside of the carrier by using your thumb.
      • Separate the shutter button from the carrier.
      Ask FixBot
    1. Canon ELPH Z3 Camera Rear Screen Replacement, Rear Screen: step 5, image 1 of 2 Canon ELPH Z3 Camera Rear Screen Replacement, Rear Screen: step 5, image 2 of 2
      • Pull apart the front and back coverings of the camera.
      • Remove the back covering completely to gain access of the rear screen.
      Ask FixBot
    2. Canon ELPH Z3 Camera Rear Screen Replacement: step 6, image 1 of 3 Canon ELPH Z3 Camera Rear Screen Replacement: step 6, image 2 of 3 Canon ELPH Z3 Camera Rear Screen Replacement: step 6, image 3 of 3
      • Unscrew the 6 4.1mm screws that are holding the back screen in place by using the PH000 screwdriver.
      • This step may require for you to pull back tape to gain access to some screws.
      Ask FixBot
    3. Canon ELPH Z3 Camera Rear Screen Replacement: step 7, image 1 of 2 Canon ELPH Z3 Camera Rear Screen Replacement: step 7, image 2 of 2
      • Pull the yellow tape away from the side that is attached to the back screen.
      • Remove the back screen.
      Ask FixBot
Katy Skillings
1 Reputation
2 Guides authored
UMass Dartmouth, Team 1-7, Catania Fall 2016 Member of UMass Dartmouth, Team 1-7, Catania Fall 2016
UMASSD-CATANIA-F16S1G7
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 28
All Time: 572
