Up to 20% off select tools
Canon ELPH Z3 Camera Image Sensor Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
7
Past 30 Days:
33
All Time:
704
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
An image sensor is a key component in a camera's function. The imaging sensor senses and converys information that creates an image. It converts the variable flux of light waves into the signals that carry this information. The main issue that can occur with an imaging sensor is dust build up. This guide provides step by step instructions to replace your imaging sensor in your Canon ELPH Z3.
    1. Canon ELPH Z3 Camera Image Sensor Replacement, Shutter Button: step 1, image 1 of 3 Canon ELPH Z3 Camera Image Sensor Replacement, Shutter Button: step 1, image 2 of 3 Canon ELPH Z3 Camera Image Sensor Replacement, Shutter Button: step 1, image 3 of 3
      • Unscrew the 7 4.1mm screws around the camera using a PH000 screwdriver.
      Ask FixBot
    2. Canon ELPH Z3 Camera Image Sensor Replacement: step 2, image 1 of 3 Canon ELPH Z3 Camera Image Sensor Replacement: step 2, image 2 of 3 Canon ELPH Z3 Camera Image Sensor Replacement: step 2, image 3 of 3
      • Split the front and back coverings of the camera.
      • Remove the back covering completely.
      • This allows for easier access to the shutter button carrier.
      Ask FixBot
    3. Canon ELPH Z3 Camera Image Sensor Replacement: step 3, image 1 of 2 Canon ELPH Z3 Camera Image Sensor Replacement: step 3, image 2 of 2
      • Slide the shutter button carrier off of the camera.
      • Notice shutter button is on the right hand side of the carrier.
      Ask FixBot
    4. Canon ELPH Z3 Camera Image Sensor Replacement: step 4, image 1 of 3 Canon ELPH Z3 Camera Image Sensor Replacement: step 4, image 2 of 3 Canon ELPH Z3 Camera Image Sensor Replacement: step 4, image 3 of 3
      • Press upward on the shutter button from the underside of the carrier by using your thumb.
      • Separate the shutter button from the carrier.
      Ask FixBot
    1. Canon ELPH Z3 Camera Image Sensor Replacement, Rear Screen: step 5, image 1 of 2 Canon ELPH Z3 Camera Image Sensor Replacement, Rear Screen: step 5, image 2 of 2
      • Pull apart the front and back coverings of the camera.
      • Remove the back covering completely to gain access of the rear screen.
      Ask FixBot
    2. Canon ELPH Z3 Camera Image Sensor Replacement: step 6, image 1 of 3 Canon ELPH Z3 Camera Image Sensor Replacement: step 6, image 2 of 3 Canon ELPH Z3 Camera Image Sensor Replacement: step 6, image 3 of 3
      • Unscrew the 6 4.1mm screws that are holding the back screen in place by using the PH000 screwdriver.
      • This step may require for you to pull back tape to gain access to some screws.
      Ask FixBot
    3. Canon ELPH Z3 Camera Image Sensor Replacement: step 7, image 1 of 2 Canon ELPH Z3 Camera Image Sensor Replacement: step 7, image 2 of 2
      • Pull the yellow tape away from the side that is attached to the back screen.
      • Remove the back screen.
      Ask FixBot
    1. Canon ELPH Z3 Camera Image Sensor Replacement, Image Sensor: step 8, image 1 of 3 Canon ELPH Z3 Camera Image Sensor Replacement, Image Sensor: step 8, image 2 of 3 Canon ELPH Z3 Camera Image Sensor Replacement, Image Sensor: step 8, image 3 of 3
      • Pull away back screen base to reveal the image sensor.
      • Remove image sensor using a set of pliers.
      Ask FixBot
Author
with
Katy Skillings
1 Reputation
2 Guides authored
UMass Dartmouth, Team 1-7, Catania Fall 2016 Member of UMass Dartmouth, Team 1-7, Catania Fall 2016
UMASSD-CATANIA-F16S1G7
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 33
All Time: 704
