Up to 20% off select tools
Canon CanoScan N670U Disassembly
Views: 2.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
26
Past 30 Days:
106
All Time:
2,132
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If you observe any problems inside your scanner, you will have to remove some components to do any work inside your Canon CanoScan N670U.
To reach the inner components of the scanner, you must:
  • Remove the two side bars that hold the glass scanner bed in place.
  • Remove the glass scanner bed itself.
    1. Canon CanoScan N670U Disassembly, Canon CanoScan N670U Disassembly: step 1, image 1 of 1
      • Open up your Canon CanoScan N670U to an upright position.
      Ask FixBot
    2. Canon CanoScan N670U Disassembly: step 2, image 1 of 1
      • Turn your device so that you're facing the long side of the Canon CanoScan N670U.
      • Locate the small crevice between the plastic components of the scanner bed and the scanner base.
      Ask FixBot
    3. Canon CanoScan N670U Disassembly: step 3, image 1 of 1
      • Carefully insert a metal spudger tool in the crevice and slowly cut through the adhesive between the plastic components.
      • You may cut small bits of the plastic as you're slicing the adhesive. Do not forcefully bend the plastic strip as you're cutting or it will snap.
      Ask FixBot
    4. Canon CanoScan N670U Disassembly: step 4, image 1 of 1
      • Once the adhesive strip is sliced through, the plastic bar that is attached should release. Set aside the plastic bar.
      Ask FixBot
    5. Canon CanoScan N670U Disassembly: step 5, image 1 of 1
      • Repeat steps 2-4 for the other side of the scanner.
      Ask FixBot
    6. Canon CanoScan N670U Disassembly: step 6, image 1 of 1
      • Use your hands or a metal spudger tool to push the plastic bar at the bottom of the glass scanner bed forward until you can't push it any farther.
      Ask FixBot
    7. Canon CanoScan N670U Disassembly: step 7, image 1 of 1
      • Insert the metal spudger tool underneath the glass scanner bed. The front of the scanner bed should be resting on top of the tool.
      Ask FixBot
    8. Canon CanoScan N670U Disassembly: step 8, image 1 of 1
      • Slowly pull the glass scanner bed towards you and set the piece aside.
      Ask FixBot
Author
with
Stephen Bui
558 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 106
All Time: 2,132
