Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓Old, degraded light seals in the Canon AE-1 can cause light leaks, leading to ruined exposures. Use this guide to replace the light seals in your Canon AE-1 to prevent these issues and extend the life of your camera.
Parts
Light seal replacement kit (or foam sheets)Affiliate linkAvailable for sale on Amazon
It is recommended to purchase pre-cut foam sheets.
Tools
Utility Scissors4.9
Hold the camera with the back facing you, and gently pull up on the rewind knob located on the top-left side of the camera using your other hand.
Carefully open the back of the camera to reveal the film compartment.
Place the camera on a clean, stable surface to access the grooves more easily and work comfortably on removing the old seals.
Congratulations! You've successfully replaced the light seals in your Canon AE-1. Enjoy shooting with your refurbished film camera!
