Canary CAN100USBK Ethernet PCB Board Replacement
  1. Canary CAN100USBK Ethernet PCB Board Replacement, Bottom Casing: step 1, image 1 of 2 Canary CAN100USBK Ethernet PCB Board Replacement, Bottom Casing: step 1, image 2 of 2
    • Grip the rubber ring with your fingers and pull up.
    • Rotate the Canary as you pull out one tab at a time.
    Ask FixBot
  2. Canary CAN100USBK Ethernet PCB Board Replacement: step 2, image 1 of 1
    • Use your Phillips #0 screwdriver to remove the four 6mm screws.
    Ask FixBot
  3. Canary CAN100USBK Ethernet PCB Board Replacement: step 3, image 1 of 3 Canary CAN100USBK Ethernet PCB Board Replacement: step 3, image 2 of 3 Canary CAN100USBK Ethernet PCB Board Replacement: step 3, image 3 of 3
    • Use the flat end of the spudger to carefully pry off the bottom casing.
    • Alternate pushing up on the left and right sides until the clips holding the case in are visible.
    Ask FixBot
  4. Canary CAN100USBK Ethernet PCB Board Replacement: step 4, image 1 of 2 Canary CAN100USBK Ethernet PCB Board Replacement: step 4, image 2 of 2
    • Do not yank the bottom off or you may damage the ribbon cable or the ZIF connector.
    • Carefully remove the bottom casing by gripping it on both sides and pulling straight up.
    Ask FixBot
  5. Canary CAN100USBK Ethernet PCB Board Replacement: step 5, image 1 of 2 Canary CAN100USBK Ethernet PCB Board Replacement: step 5, image 2 of 2
    • Use the pointed end of the spudger to flip up the small retaining flap on the ZIF (zero insertion force) connector.
    • Pull the ribbon cable out towards the device.
    Ask FixBot
  6. Canary CAN100USBK Ethernet PCB Board Replacement, Ethernet PCB Board: step 6, image 1 of 1
    • Use your Phillips #0 screwdriver to remove the three 5mm screws.
    Ask FixBot
  7. Canary CAN100USBK Ethernet PCB Board Replacement: step 7, image 1 of 2 Canary CAN100USBK Ethernet PCB Board Replacement: step 7, image 2 of 2
    • Place the flat end of the spudger underneath the Ethernet PCB board and slowly pry up until it's loose.
    Ask FixBot
  8. Canary CAN100USBK Ethernet PCB Board Replacement: step 8, image 1 of 1
    • Carefully pull the Ethernet PCB board away from the board that sits underneath.
    Ask FixBot
Tommy Nguyen
597 Reputation
5 Guides authored
USF Tampa, Team S1-G2, Nance Spring 2017 Member of USF Tampa, Team S1-G2, Nance Spring 2017
USFT-NANCE-S17S1G2
4 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 29
All Time: 1,313
