Canary CAN100USBK Audio and USB PCB Board Replacement
  1. Canary CAN100USBK Audio and USB PCB Board Replacement, Bottom Casing: step 1, image 1 of 2 Canary CAN100USBK Audio and USB PCB Board Replacement, Bottom Casing: step 1, image 2 of 2
    • Grip the rubber ring with your fingers and pull up.
    • Rotate the Canary as you pull out one tab at a time.
    Ask FixBot
  2. Canary CAN100USBK Audio and USB PCB Board Replacement: step 2, image 1 of 1
    • Use your Phillips #0 screwdriver to remove the four 6mm screws.
    Ask FixBot
  3. Canary CAN100USBK Audio and USB PCB Board Replacement: step 3, image 1 of 3 Canary CAN100USBK Audio and USB PCB Board Replacement: step 3, image 2 of 3 Canary CAN100USBK Audio and USB PCB Board Replacement: step 3, image 3 of 3
    • Use the flat end of the spudger to carefully pry off the bottom casing.
    • Alternate pushing up on the left and right sides until the clips holding the case in are visible.
    Ask FixBot
  4. Canary CAN100USBK Audio and USB PCB Board Replacement: step 4, image 1 of 2 Canary CAN100USBK Audio and USB PCB Board Replacement: step 4, image 2 of 2
    • Do not yank the bottom off or you may damage the ribbon cable or the ZIF connector.
    • Carefully remove the bottom casing by gripping it on both sides and pulling straight up.
    Ask FixBot
  5. Canary CAN100USBK Audio and USB PCB Board Replacement: step 5, image 1 of 2 Canary CAN100USBK Audio and USB PCB Board Replacement: step 5, image 2 of 2
    • Use the pointed end of the spudger to flip up the small retaining flap on the ZIF (zero insertion force) connector.
    • Pull the ribbon cable out towards the device.
    Ask FixBot
  6. Canary CAN100USBK Audio and USB PCB Board Replacement, Ethernet PCB Board: step 6, image 1 of 1
    • Use your Phillips #0 screwdriver to remove the three 5mm screws.
    Ask FixBot
  7. Canary CAN100USBK Audio and USB PCB Board Replacement: step 7, image 1 of 2 Canary CAN100USBK Audio and USB PCB Board Replacement: step 7, image 2 of 2
    • Place the flat end of the spudger underneath the Ethernet PCB board and slowly pry up until it's loose.
    Ask FixBot
  8. Canary CAN100USBK Audio and USB PCB Board Replacement: step 8, image 1 of 1
    • Carefully pull the Ethernet PCB board away from the board that sits underneath.
    Ask FixBot
  9. Canary CAN100USBK Audio and USB PCB Board Replacement, Audio and USB PCB Board: step 9, image 1 of 1
    • Using your fingernails, wiggle the power connector back and forth until it becomes loose.
    • Pull the power connector straight out of the socket.
    • Pull only on the power connector and not the wires themselves to prevent damage.
    Ask FixBot
  10. Canary CAN100USBK Audio and USB PCB Board Replacement: step 10, image 1 of 3 Canary CAN100USBK Audio and USB PCB Board Replacement: step 10, image 2 of 3 Canary CAN100USBK Audio and USB PCB Board Replacement: step 10, image 3 of 3
    • Use the spudger to pry up the retaining flap of the ZIF connector.
    • Disconnect the ribbon cable.
    Ask FixBot
  11. Canary CAN100USBK Audio and USB PCB Board Replacement: step 11, image 1 of 1
    • Remove the two Phillips #0 5mm screws.
    Ask FixBot
  12. Canary CAN100USBK Audio and USB PCB Board Replacement: step 12, image 1 of 2 Canary CAN100USBK Audio and USB PCB Board Replacement: step 12, image 2 of 2
    • Pull the board away from the bottom casing by lifting the end closest to the chimney up.
    Ask FixBot
3 other people completed this guide.
Kristopher Gates
399 Reputation
3 Guides authored
USF Tampa, Team S1-G2, Nance Spring 2017 Member of USF Tampa, Team S1-G2, Nance Spring 2017
USFT-NANCE-S17S1G2
4 Members
16 Guides authored
2 Guide Comments
Hello great tutorial I have a problem with the usb on mine.
Where did you buy the PCB from?
craig perrin - Reply Share
nice guide, need to buy the ep-cnc01bb-02 board which has the micro usb on it as mine is worn out... any ideas?
Billy - Reply Share
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 34
All Time: 1,354
