This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Community-Contributed Guide
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓I replaced my VVT solenoid at 111,000 km due to a suspected failure, despite an impeccable oil change schedule.
My initial problem was unfortunately not resolved; it must have still been working and had absolutely no trace of deposits, but here is a guide for anyone who wishes to replace this part ;)
Reminder: only the intake camshaft has variable valve timing (VVT) on H4D/H4Bt engines. Therefore, there is only one VVT solenoid at this location.
Guide shown on an H4D, applicable to the H4Bt.
Unscrew the 6 screws by hand or with a T50 socket.
Lift and set aside the engine hood.
Clean the area around the solenoid as best as you can. Once it is removed, the hole leads directly into the oil circuit: you do not want any contaminants inside.
Spray penetrating oil at the base of the solenoid in advance and let it sit.
Remove the VVT solenoid by pulling it straight out. The use of a tool is highly recommended. Rotating the solenoid to loosen it is a good idea.
Verify that the seal came out with the extracted part.
Plug the hole with something like paper towels, being very careful not to let any contaminants enter.
Clean the entire contact surface where the new solenoid will be installed. You may need to scrape it using tools.
Lubricate the solenoid with clean engine oil.
Insert the solenoid into the orifice until it stops, taking care not to scratch the walls.
Tighten the single 8 mm screw to 10 N·m.
Reconnect the solenoid connector.
Clear the OBD fault codes.
Start the engine and check that the original fault has disappeared. Also check that oil is not leaking from the new VVT solenoid.
Perform a road test while observing the engine behavior.
Once the engine is warm (hot oil), with the engine running on flat ground in neutral, run the "VVT After Sales" routine using a Renault diagnostic tool.
Proceed to clear the OBD error codes, then perform a test drive to see if the failure symptoms have disappeared.
Check that no oil is leaking from the solenoid.
3 other people completed this guide.
2 Guide Comments
Hello !
Pour information, sur ma Twingo 3 phase 1 avec le H4BT, j'ai eu un dysfonctionnement du solénoïde à 90000km. Il restait bloqué des fois dans certaines positions, ce qui entrainait des régimes moteurs instables. Au ralenti, le moteur était entre 600 et 900 tr/mn avec la sensation qu'il manquait un cylindre.
J'avais 2 défauts qui remontaient à la valise :
DF362 : Décaleur Arbre à Cames - Défaut d'asservissement
DF363 : Décaleur arbre à cames - Asservissement du décaleur hors limite
Après remplacement du solénoïde (sans la procédure à la valise VVT After Sales, j'ignorais son existence à l'époque) plus aucuns soucis, les défauts ne sont jamais revenus.
Bonjour pourrais-je avoir son emplacement exacte
Merci
