Campbell Hausfeld FP204800 Check Valve Replacement
    1. Campbell Hausfeld FP204800 Check Valve Replacement, Remove Shroud Screws: step 1, image 1 of 3 Campbell Hausfeld FP204800 Check Valve Replacement, Remove Shroud Screws: step 1, image 2 of 3 Campbell Hausfeld FP204800 Check Valve Replacement, Remove Shroud Screws: step 1, image 3 of 3
      • Unscrew the four 1cm long shroud screws using a 6mm Allen Wrench.
      Ask FixBot
    2. Campbell Hausfeld FP204800 Check Valve Replacement, Remove Shroud: step 2, image 1 of 2 Campbell Hausfeld FP204800 Check Valve Replacement, Remove Shroud: step 2, image 2 of 2
      • Remove the plastic shroud from the compressor.
      • Do not pull the shroud too far from the compressor. You could damage the on/off switch wiring.
      Ask FixBot
    3. Campbell Hausfeld FP204800 Check Valve Replacement, Remove The Wiring From the Pressure Switch to the On/Off Switch: step 3, image 1 of 1
      • Gently pull the wire attached from the pressure switch to the on/off switch.
      • It should come off the pressure switch with ease.
      • Make sure you are pulling the correct wire. The pressure switch could be in a different configuration on your compressor than in the picture.
      Ask FixBot
    4. Campbell Hausfeld FP204800 Check Valve Replacement, Remove the On/Off Switch Wiring: step 4, image 1 of 1
      • Gently pull the wire connected from the on/off switch to the motor of the compressor.
      • It should be the only wire keeping the shroud from being lifted from the compressor.
      Ask FixBot
    1. Campbell Hausfeld FP204800 Check Valve Replacement, Unscrew Exhaust Tube: step 5, image 1 of 1
      • Unscrew the exhaust tube from the check valve using a Smart Wrench.
      Ask FixBot
    2. Campbell Hausfeld FP204800 Check Valve Replacement, Unscrew Check Valve: step 6, image 1 of 1
      • Unscrew the check valve by twisting it counter-clockwise using a Smart Wrench.
      Ask FixBot
Caleb Davies
543 Reputation
4 Guides authored
Cal Poly, Team 14-29, Maness Fall 2014 Member of Cal Poly, Team 14-29, Maness Fall 2014
CPSU-MANESS-F14S14G29
4 Members
63 Guides authored
2 Guide Comments
I never thought that it will be that much easy. I was looking for this kind of guide and thanks to ifixit and author of this guide I have successfully did the check valve replacement. Thanks for sharing this.
http://zahroofvalves.com
Rodney A. Olsen - Reply Share
1. How do you know if it’s the pressure switch that’s bad?
2. What do ya do when they say the parts are discontinued??
Jennifer Epps - Reply Share
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 37
All Time: 1,994
