Cambridge Audio A3i Motherboard Replacement
  1. Cambridge Audio A3i Motherboard Replacement, Case: step 1, image 1 of 1
    • Remove 2 screws from each side of the amplifier.
    Ask FixBot
  2. Cambridge Audio A3i Motherboard Replacement: step 2, image 1 of 1
    • Remove 2 screws on rear of device. Slide top cover up and back from main case.
    Ask FixBot
  3. Cambridge Audio A3i Motherboard Replacement: step 3, image 1 of 2 Cambridge Audio A3i Motherboard Replacement: step 3, image 2 of 2
    • Remove 3 screws on bottom of case.
    • Remove 13 screws on rear panel.
    • Do not move the rear panel too far, as the power cord is still connected.
    Ask FixBot
  4. Cambridge Audio A3i Motherboard Replacement: step 4, image 1 of 1
    • Using a pair of pliers, squeeze the retainer for the power cord as shown and pull it toward the external side the panel.
    • It may require some wiggling, but it should slip out of the hole and then off of the cord.
    Ask FixBot
  5. Cambridge Audio A3i Motherboard Replacement, Motherboard: step 5, image 1 of 1
    • Remove 2 screws from each side of the heatsink. These must be accessed from directly above the device.
    • Remove the green grounding wire from the mounting screw.
    Ask FixBot
  6. Cambridge Audio A3i Motherboard Replacement: step 6, image 1 of 1
    • With the amplifier on it's side, remove the 4 screws that hold the motherboard frame to the main case.
    • Be sure to hold the motherboard with one hand while removing the mount screws.
    Ask FixBot
  7. Cambridge Audio A3i Motherboard Replacement: step 7, image 1 of 2 Cambridge Audio A3i Motherboard Replacement: step 7, image 2 of 2
    • Unscrew ground wire from main case.
    • De solder 4 wires coming from transformer.
    • The motherboard can now be lifted from the case. Any part that needs to be removed from it can be de-soldered.
    Ask FixBot
Colby
356 Reputation
3 Guides authored
Cal Poly, Team 28-36, Regan Spring 2010 Member of Cal Poly, Team 28-36, Regan Spring 2010
CPSU-REGAN-S10S28G36
4 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 58
All Time: 7,537
