CamPark BM20 Buttons Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
55
All Time:
329
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If the buttons of your CamPark BM20 baby monitor are jammed or broken, follow this guide to replace them.
Before using this guide, review the Buttons Not Responding troubleshooting page to see if one of those steps fixes the issue you are experiencing.
In step 4, the volume button will come off easily when prying open the unit. In step 5, there is a gray wire attached to the motherboard. Be careful not to pull the motherboard forcefully.
Make sure to power off the device before beginning the repair.
Tools
    1. CamPark BM20 Buttons Replacement, Battery: step 1, image 1 of 3 CamPark BM20 Buttons Replacement, Battery: step 1, image 2 of 3 CamPark BM20 Buttons Replacement, Battery: step 1, image 3 of 3
      • Flip the handheld monitor so the back is facing you.
      • Use your fingers to slide the battery cover off to access the battery.
      Ask FixBot
    2. CamPark BM20 Buttons Replacement: step 2, image 1 of 2 CamPark BM20 Buttons Replacement: step 2, image 2 of 2
      • Use a spudger or your fingers to unplug the battery cable from the handheld device.
      • Remove the battery.
      Ask FixBot
    1. CamPark BM20 Buttons Replacement, Buttons: step 3, image 1 of 3 CamPark BM20 Buttons Replacement, Buttons: step 3, image 2 of 3 CamPark BM20 Buttons Replacement, Buttons: step 3, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the three 12.7 mm screws from the lower back of the device.
      • Insert the tip of an iFixit opening tool between the front and back casing seams to release the clips securing the two halves.
      • Gently pry apart the handheld unit.
      Ask FixBot
    2. CamPark BM20 Buttons Replacement: step 4, image 1 of 3 CamPark BM20 Buttons Replacement: step 4, image 2 of 3 CamPark BM20 Buttons Replacement: step 4, image 3 of 3
      • Unplug the speaker cable from the socket on the motherboard.
      Ask FixBot
    3. CamPark BM20 Buttons Replacement: step 5, image 1 of 1
      • Using a Phillips #00 screwdriver, remove the four 6.35 mm screws from the corners of the motherboard.
      Ask FixBot
    4. CamPark BM20 Buttons Replacement: step 6, image 1 of 2 CamPark BM20 Buttons Replacement: step 6, image 2 of 2
      • Remove the motherboard from the front case and set it on the bottom case with the speaker.
      Ask FixBot
    5. CamPark BM20 Buttons Replacement: step 7, image 1 of 3 CamPark BM20 Buttons Replacement: step 7, image 2 of 3 CamPark BM20 Buttons Replacement: step 7, image 3 of 3
      • Remove the volume and directional buttons from the top cover.
      • The power and speaker buttons cannot be removed without breaking them off.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Subah Shabnam
837 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 55
All Time: 329
